Home > Puma (Tdci) > keyfob issues |
no battery in the key fob is this true NO if you have factory key fob the battery is CR2032 LR part number YWK10003L
LR factory key fob Last edited by dorsetsmith on 6th Nov 2017 12:38pm. Edited 1 time in total |
6th Nov 2017 12:26pm |
Boris Member Since: 02 May 2014 Location: Oswestry Posts: 21 |
thank you , I thought it was a load of blarney .
is it just a case of changing the battery or do I have to face northwards standing on one leg with my tongue out |
6th Nov 2017 12:38pm |
6th Nov 2017 12:41pm |
Sockpuppet Member Since: 17 Sep 2011 Location: Leicester Posts: 479 |
Nope just change it over. The batteries are very common most corner shops should sell, I carry a few in the glove box just in case.
6th Nov 2017 12:42pm |
thank you very much will nip in to town and get a battery
6th Nov 2017 12:44pm |
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 |
Please send pics 1983 Series 3 Pick up in Marine Blue 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
6th Nov 2017 12:50pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
Whilst I too would like to see the above photos.... you might also like to follow the following which worked for me
Procedure(basics).... Insert key and turn to position II(ignition on). Turn key to position O(Ignition off). Remove the back of the fob and remove the battery. Hold one button for minimum 5 seconds to drain any residual power in the fob. Fit the new battery ensuring contacts are clean and polarity is correct. Reassemble the fob. From outside the car operate the LOCK button at least 4 times(this synchronises the fob). Press unlock to unlock. All done. PS I cannot believe the main dealer said it doesn't have a battery that's just disgraceful service! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
6th Nov 2017 1:20pm |
James you beet me to it
6th Nov 2017 1:32pm |
or just pop it open and swap the battery. The push the lock button 4 or 5 times to resync it. I've done that loads of times without bothering with the above and suffered no adverse effect. I've also done it on Rover fobs (same fob as early Puma's) for at least 20 years.
It's true of the latest keyless ignition vehicles (ie Range Rover, Discovery etc), i expect they were just getting confused about which fob you had. As yours is a 2014 car, i expect the fob is the newer style with the chrome bit on it? The look identical to the keyless entry ones used on the current range. |
6th Nov 2017 5:42pm |
Newer style with the chrome bit on it? OK see below still has Battery CR2032 fitted
https://www.defender2.net/gallery/albums/u...282%29.pdf |
6th Nov 2017 6:16pm |
Exactly, but the dealer parts bod probably just looked at the fob and mistook it for the Range Rover/Discovery type one, as they look the same.
7th Nov 2017 12:42am |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 402 |
I have the new style fob, it’s been flat for some time.
I have just replaced the battery and it won’t unlock the car at all. I Have tried the old method of key - 2 back to 0 and press the button a few times to sync. Any ideas? |
4th Oct 2018 11:36am |
d-digby Member Since: 02 Aug 2013 Location: New Forest Posts: 12 |
Thanks all
I've got a replacement key from remotekey.co.uk and couldn't get it working after replacing the battery. Followed the steps above and worked first time Barry |
4th Oct 2018 1:51pm |
