Home > Td5 > Towing issue with a td5 |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6463 |
Can you check with another trailer of similar load to either confirm it's the Defender... or tow the horsebox with something else to eliminate that as the cause? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
14th Sep 2018 12:27pm |
Djcla Member Since: 29 Jul 2017 Location: Gloucestershire Posts: 469 |
Yes ill get some one else to try towing it thats a good shout..
14th Sep 2018 12:53pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Feel all brakes on the vehicle (including handbrake drum) and check trailer brakes for excisive heat, in case you have a brake that's binding. Also, check for any oil leaks, it is surprising how a little bit of oil on a slightly hotter engine caused by towing can cause a smell similar to clutch and brakes. You could also try dipping the clutch and see when releasing the pedal where its bites, anything up to the halfway point is fine if it's only biting after the halfway point this could indicate a failing clutch. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
14th Sep 2018 1:00pm |
