Home > V8 > On the hunt for an original 90 3.5 V8 |
Advanced Factors Site Sponsor Member Since: 06 Jun 2013 Location: Southampton Posts: 177 |
Any around for sale? Paul Redding +44 (0)23 8052 2760 www.advancedfactors.co.uk Site Sponsor for Aftermarket Parts Last edited by Advanced Factors on 12th Sep 2018 4:53pm. Edited 1 time in total |
12th Sep 2018 3:18pm |
LEZ Member Since: 22 Oct 2015 Location: London Posts: 163 |
Maybe also ask on the Defender50th site.
12th Sep 2018 3:31pm |
Paul Redding
+44 (0)23 8052 2760 www.advancedfactors.co.uk Site Sponsor for Aftermarket Parts |
12th Sep 2018 3:32pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
Paul,
Although I appreciate that you are not actually trying to do anything untowards here, it is essentially cloning/ringing a vehicle. As you are presumably using a second hand TD5 chassis you should keep the ID from that vehicle. The DVLA points system would require that you retain the chassis and several other components from the original vehicle ID to retain the number. I assume you will be trying to apply only the VIN from the original V8 to a vehicle made from newer parts? Is this just to avoid the issues with emmisions/cataylic converters from using the TD5 age ID? I agree that this system does not lend itself quite as well to Land Rovers as it is quite easy to swap engines, axles and gearbox with genuine reasons. But the chassis should really match the original vehicle registration or be a brand new ID-less chassis which can be classed as a replacement part. If your TD5 chassis is brand new with no ID it is a little better but still not great IMO. Dont want to be the voice of doom, just want you to be aware... Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
12th Sep 2018 4:26pm |
Yes Steve it can be a minefield, trying to build with a central rear tank for the extra fuel capacity, (ROW) Rest of world TD5 Chassis. Paul Redding
12th Sep 2018 4:41pm |
