Home > My Defender > Grafty's Td5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10509 |
^^^ 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
15th Aug 2018 10:51pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
FINALLY the locking tools have arrived. So this evening I popped the head off. I foolishly assumed that being a 15p my engine would have metal dowels. Turns out that they were plastic. (Early 15p)
So a bit of head float and pistons in cyl 2, 3 and 4 have interfaced with the valves. Nothing major but there is a tiny mark in those 3 pistons Anyway the bores look great (can still see the honing marks) and have no lip. Looking at the gasket there are no obvious signs of gasket failure but there might not be if there has been head float. Tomorrow I'm going to be enquiring about having the head pressure tested and hopefully start getting things back together by the and of the week 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
20th Aug 2018 8:58pm |
Yeah absolutely, everything is looking very good, 130k miles on plastic dowels at near double factory output isn't too shabby. Shows that I drive it like Miss Daisy 2002 90 Td5 Station Wagon
20th Aug 2018 10:09pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4937 |
good stuff grafty Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
20th Aug 2018 11:43pm |
Well, things are not as dandy as they first appeared
Today, I decided to clean up the head in preparation for having it pressure tested. In removing the carbon and stuck gasket material the true extent of the problem showed itself. The head float has been so extreme and (it would appear) has been going on for quite some time as the head is actually burred around cyl 3, 4 and 5 To make matters worse, my local landrover dealer has sent out the wrong parts So I'm going to be replacing with an AMC head. Hopefully I can get it all done before my trip to the Nürburg Ring in September Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
22nd Aug 2018 9:59pm |
At least you have finally found the problem and hopefully you can get it all done before you have your trip 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
22nd Aug 2018 10:09pm |
At least that's made the decision for you, yeah its a pain when that happens with the wrong parts. I was given the wrong locking tool for the bottom end. So when it came to doing the timing belt, things were not right.
What has caused the head float? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
22nd Aug 2018 11:42pm |
Plastic head dowels Procta. Very common for them to break, allowing the head to move and cause the above damage. Brilliant idea from landrover 2002 90 Td5 Station Wagon
23rd Aug 2018 6:56am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
Are you sure |
23rd Aug 2018 10:19am |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
George,
hope you get this 'challenge', never a problem!, resolved soon. Everything crossed for you,#Cheers, Simon |
23rd Aug 2018 10:23am |
The early (10p) engines were renown for head gaskets running standard. The 15P (circa 2002)engines should have metal dowels to stop the head moving around, should it lift. Unfortunately, and not surprising the Lanrdover employee used the whats at hand approach when building Georges engine coupled with his extras its proved costly. However with the need for another Head, another modification can be made |
23rd Aug 2018 10:28am |
New AMC head ordered from Wards Engineering, my valve gear will be going in and I'm having solid metal dowels turned to make sure this never happens again!
They have assured me that it will be with me before the end of next week. Looks like the Nürburg Ring is still on 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
23rd Aug 2018 10:58am |
Thought about Low comp pistons ??I know you can get uprated head bolts but not cheap
23rd Aug 2018 11:40am |
I am sure the k series engine had a similar problem with the dowels. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
23rd Aug 2018 1:03pm |
