Home > My Defender > Proctas Defender 300TDI |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 4908 |
Ok, i will get those, from the landy when i get it back. I have them still in the original bag. Give me a PM of your address, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
7th Aug 2018 9:20pm |
Been over this morning to drop off a couple of items to get it through its mot, The lad recons the timing belt is the original one He had a right nightmare of a job getting the pulley off! so its been a ticking time bomb on me.
A few other things have been picked up, but I am going to get them to give it a once over, i told them the bodges etc that we have come a cross. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
8th Aug 2018 9:18am |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
Good move with the timing belt. When I got grover at 104,000 miles 2 years ago, I had the garage change the belt and a few other bits as part of the deal. Last years MOT went well with a few advisories for bushes that needed attention, so following that MOT it was straight back to my garage (Tredown) for them to change these bushes and put the blanking plate on the EGR. This year it sailed through again but had an advisory for a slightly frayed driver seat belt, common thing as they get caught in the drivers door. Thing is I've changed my doors to series doors and it doesn't seem to be a problem any more. I'll get a lighter on the fraying to resolve this issue and get some new belts in due course.
Liking the new wheels, well done chap, |
8th Aug 2018 9:40am |
Mine has been picked up on the seatbelt fray too on the driver side, I may change that this year once I have got my money back up. Been bloody expensive this month! I have nearly spent well over 1k on the car in a matter for days!
The thing I have found with mine, it stated it was serviced at 90k, but I think all they did was change the oil and filters. The brakes had not been seen to in a hell of a long time, and those were in such a bad way when we looked at them. One of the rears had packed up! Also not to mention the MOT it had when I bought it, There were some major failures, a ball joint that had failed, a rear damper that had leaked oil, a major fuel leak, rot on the chassis, ( they had fixed one side) a glued seatbelt stalk. ( I found this out last month) Even though it was the best out of the 5 we looked at, it still hasn't been looked after at all, well properly anyway. So the past 2 years I have it, its all about ironing out these things, and dealing with more problems. I have had to save up the budget to get the proper wheels on the car! The old ones were lethal in the wet and snow! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
8th Aug 2018 10:58am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10427 |
As said, easy fixes and not big expensive ones 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
8th Aug 2018 8:50pm |
Looks like the garage is milking this like, I haven't put any tabs on the bearings................... well there is a photo on here with them on! we did reuse the old ones as I remember so looks like they have something but not letting on Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
9th Aug 2018 11:52am |
I think it’s just defender that cost a fortune to run mine is well looked after, if it needs it, it gets it, but it’s still cost about 2k in the last three months or so Ray My build thread http://www.defender2.net/forum/topic17615.html |
9th Aug 2018 4:54pm |
I think we are well close to 600 to 800 now for the mot, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
10th Aug 2018 8:43am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2520 |
What are the issues with it?
10th Aug 2018 11:31am |
well I went over today as it should have been done today, turns out its still in bits, The stub axle on the front passenger side, has been damaged. So it wont let the bearing tighten up, also the spacers were not the correct ones either. So those have had to be changed all round.
We did get a full bearing kit with the spacers, so either we have been given the wrong spacers with the kit who knows, on that one. Going back to the stub axel, who ever has serviced it before us, as damaged it. The tester said the end has been damaged with tools, looks like they may have tried to de burr it or something. So it wasn't letting the bearing tighten up as it should. So we wouldn't have known anyway on that one, So they have had to order more parts off. so looks like we could be back with it on Tuesday or even Wednesday. Retroanaconda it failed on a spit full of items ( like loose wheel bearings and the drag link and two daft things) So I let the garage deal with that, but its turned out to be more of a job. So Christ knows how much in labour its going to cost! Timing belt has not been changed at all, and was the original one on! So the garage who has been looking after this before me, has been taking the out of the owner, the MOT tester shook his head when I told him what we have found. He said the trouble is too many places are doing this sort of thing sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
11th Aug 2018 8:18pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
For things like timing belts etc I think it's always best to ask the garage to see the old items and in this day and age they should be able to take a photo to at least show you they've had the timing cover off!
Hopefully the garage it's at now will sort everything properly 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
11th Aug 2018 9:49pm |
I did ask to see the belt, grafty as I had my suspected its not been changed, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
11th Aug 2018 11:46pm |
Procta,
Only time will tell if you have found a 'good' garage. If they resolve the issues you have highlighted then those jobs will then be done. No one likes spending out unnecessarily but completed jobs are all 'tick off' items. Wish list and other items you covert have to go on the back burner. Safety first in my book. I must have found a good one with Grover. He had lived a hard life in the Dales prior to coming down to Devon. He's not good looking but all the oily bits were in good order and had been maintained- thankfully! before I took him on. Good garages- one's you have faith in, are hard to find but once found that relationship need to be cultivated. I find cream cakes and a good sense of humor have helped me. Bodywork I can have a go at but oily bits cause my eyes cloud over. Carry on the good work. Cheers, Simon |
12th Aug 2018 7:22am |
You could have saved a bunch of cash by just getting the garage to do the MOT and then fixing the rest yourself? The only way to know the quality of the work being done on your car is to do it yourself.
12th Aug 2018 8:46am |
