Home > Puma (Tdci) > 2.2 Air Conditioning Leak |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 172 |
Under the heater / zircon unit in the dash is a rubber grommet that connects the unit to the floor and through to the duckbill. Check the grommet. It will be pretty to check but that is what I would do.
Has your dash or heater / aircon unit ever been removed? (and not fitted back correctly?) 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
20th Sep 2016 9:43am |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
The little rubber drain pipe teat will be blocked and back filling until leaking, situated above the gearbox. have a feel around up there and you should find it, give it a squeeze and you should hopefully get wet
20th Sep 2016 10:15am |
Smithy Member Since: 25 Jul 2010 Location: Monmouthshire Posts: 21 |
Many thanks both I shall sort on the weekend and let you know how I get on
21st Sep 2016 9:36pm |
Many thanks guys I think the problem is solved.
Nick, as you said it would be pretty difficult to access so I followed Roy's advice and found the duck bill above the gearbox an squeezed gently until it opened, no water came out probably because I haven't used the air con for a while. It,s been over a week with air con on and no leaks so a big thanks. Smithy |
29th Sep 2016 2:32pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Thanks Roy5695 ! Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
6th Aug 2018 11:13am |
