Home > Td5 > Rough starting now cutting out
drinkdrinkdrop
Got (another) problem with my td5, started off as a bit of a rough idle or needing a little rev when starting which within a a week or so progressed to letting the fuel pump run for 15secs before cranking then needing a purge before starting now it’s a pig to get going with loads of cranking and right foot in a cloud of smoke at which point I can go about half a mile before it cuts out. Fuel pump screams the whole time regardless of how many purges I do (after market louder than genuine but both scream)
Things i’ve Tried
Red plug clean
New filter
New genuine air bleed valve
Swapped fuel pump
Cleaned and refitting all filter housing elements
FPR and filter head less than 2months old one of the pumps is also only a couple of months old. I had seals and washers done about 3 months ago but based on the symptoms appear the likely culprit.
Can I check the injector clamp torques without removing the camshaft? And does anyone have any suggestions of other things to check
Post #720955 2nd Aug 2018 7:21am
Defender NZ
New Zealand 2003 Defender 90 Td5 HT Caledonian Blue
Good day DDP Smile
Sounds very much like the washers on the injectors.
I had exactly the same, but when replaced the washers she's been as good as gold Thumbs Up
I bought the kit from Dingocroft in HIGH Wycombe, and did it in our workshop !
Make sure your get the genuine washers though hey ?? and keep it spotless when to do them Wink
Hope that helps Rolling Eyes
Post #729484 17th Sep 2018 10:46am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Yea definitely sounds like injector washers, easy job can be done in a few hours Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #729499 17th Sep 2018 11:42am
drinkdrinkdrop
Yeah it turned out to be injector copper washers again, had them done by a different garage this time.
Post #729501 17th Sep 2018 12:02pm
Defender NZ
Good one Thumbs Up
Post #729504 17th Sep 2018 12:19pm
