Home > In Car Electronics > Removal/Replace Stock Cig Lighter Plug 2014 110 |
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 |
Id like to swap the stock 12v lighter socket for a dual USB charger...
How do I access the lighter to remove the stock one? I found this post- cant tell if it needs to be this involved in order to get to it or not. Hope to replace with a BlueSea 5amp dual charger. http://www.defender2.net/forum/topic16968....oval+guide |
27th Jul 2018 2:12pm |
Al_The_Pal Member Since: 09 Feb 2015 Location: Near the bottom on the right Posts: 146 |
PS that guide looks right, but it’s not that scary once you unscrew the middle panel.
27th Jul 2018 11:08pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19531 |
Just remove centre dash, snap off plastic retaining 'tangs' to the rear and it may be tight but will slide out.
Not reallly worth trying to save, they aren't designed to be removable then replace. .Blue sea are very nice, either 12v or USB versions. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
28th Jul 2018 12:15am |
