Home > Puma (Tdci) > fuel breather pipe |
newhue Member Since: 28 Apr 2014 Location: Brisbane Posts: 351 |
Well its still early days but I'm pleased to say, for me anyway, I have fixed the fuel leak deal. I have driven for an hour on a hot day with a 1/4 tank, filled up, driven for another hour and no leaking. Now I'm down to 1/2 tank again all on hot days, parked in the sun and all is normal. Before swapping the valve around I would have seen new wet diesel stain all over the fill pipe, breather, chassis, tank neck and and body going down under to the bash plate; instead I have none or it. When I release the fill cap immediately after driving I get a very small breath in. Way less than the old whoosh out. If I let it sit for some time after stopping I get nothing. Car runs fine. Cars is running so well I have started wondering if the 20lt of light grey smoke I have been getting on start up after sitting overnight, could possibly be related to an over pressurised fuel tank. Because I'm not getting it anymore. But then I guess it could also be just a Land Rover thing.
LR have the big end facing the breather pipe. I reckon it should look like this. My Defender and travels |
6th Oct 2017 8:55am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2287 |
I see D2N is referenced on this topic, on the Land Rover Workshop site...
(keep up the good work everyone ) Click image to enlarge Click image to enlarge https://www.landroverworkshop.com/diagrams...er_45023#9 SKIP https://www.defender2.net/forum/topic83242.html |
2nd Nov 2017 11:14am |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 558 |
Mine Is in the dealers today having this looked at. I got a call this afternoon saying it had all been approved under warranty and it was leaking because the valve was on the wrong way round from new!!
I wasn’t surprised!! They recon ill have it back tomorrow but I won’t hold my breath as they had the truck for three months last time it went in. |
12th Mar 2018 8:38pm |
Credit to Hatfield’s Liverpool this time.
Two days and they have replace all pipes to the tank bar the large filler pipe. Other work was done all under warranty. Much better service than last time. Click image to enlarge Click image to enlarge Click image to enlarge |
13th Mar 2018 9:17pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19531 |
Mine is starting to perish so this thread has been very interesting.
Glad to see for once it's not something really expensive to repair. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 Last edited by custom90 on 7th Oct 2018 6:48pm. Edited 1 time in total |
20th Jul 2018 6:58pm |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
got mine back yesterday guy salmon Wakefield did it no charge apparently they tend to twist too
21st Jul 2018 4:18pm |
Nevillerover Member Since: 14 Feb 2015 Location: Suffolk Posts: 224 |
Remove rear wheel.
The hardest part of this job is getting the original crimped ring off but with the right technique it is a 5 minute job. get one of those hacksaw blade handles so you can hold it at the end. Go in via the hole that the big fuel pipe passes through and you can get the other end of the blade onto the clip but wont be able to get any pressure on it to be effective. So, get a length of mild steel flat bar, mine is about 10mm wide, and hacksaw a small cut into the end around 7mm deep. You can poke that in from a point a bit further towards the front of the car and get it onto the end of the blade. It will hold the blade at 90° to the clip and allow you to apply pressure. Move both hands back and forth at same time and voila! a few minutes later a nice ping as the clip comes off. Lube tube and pull it off and through chassis. Get a new bit of 20mm ID fuel pipe, lube that and push through chassis, slip a Jubilee over, push and twist until you get the pipe on the tank connector. I manages to tighten the Jubilee using a long extension with a universal joint on the end. Although it took me half a day (including driving to town to get some pipe) if i had to do another, I reckon 30 minutes if I had all the tools and pipe lined up ready to go. |
12th Mar 2019 2:28pm |
skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 51 |
Did mine as well. My $AU 0.02 worth of hints:
- Pretty sure it was the original one in the car, so it had 9 years of life - I didn't remove the tank (MY10 110) - Removing the mud flap and its bracket is easy and gives much-needed working room. - I was able to unclip the hose clip on the tank end (i.e. not hacksaw it) - I used a heavy awl-type sewing needle (one of those odd things you keep in your toolbox...), and was able to lever the end of the clip up, so it just sprung off. If you have bought the "factory" replacement pipe, have a practice on the clips on that before you do it for real - you have to do it by feel pretty much. - I extended the pipe for the one-way valve so it is all the way up behind the plastic plate over the tail lights - way out of the way of water etc. - I ran the "large" breather through the same gap as the main filler hose (i.e. not the factory "squish" above the chassis rail) based on the success reported by others. |
25th May 2019 6:53am |
Rus Member Since: 16 Jul 2019 Location: cape town Posts: 2 |
Thanks for all the advice. I have a puma 90 that needs a breather pipe replacement.
Any advice on how to drop or move the fuel tank. I've undone all the bolts but it doesn't budge. |
16th Jul 2019 11:59am |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 745 |
The breather pipe on my 2010 2.4 110 is leaking. I've looked through this thread which really helpful but mine seems to have a straight pipe from the tank to filler, no T piece as in some of the photos on here. Was the T piece a 2.2 evolution.
Was this T piece added later on? Am I ok with just a straight replacement pipe? |
2nd Sep 2019 8:24pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
Yes, the breather and filler vent pipes evolved over time (and got worse). Replace like with like.
You might want to read my posts on page 2 of this thread, made a long, long time ago. |
2nd Sep 2019 10:09pm |
Brilliant thanks. Good to keep it simple.
2nd Sep 2019 10:15pm |
Thanks Black Wolfe. A simple job to do in the end by dropping the tank. Used high grade marine pipe which should outlast me! Can’t understand why they crush the pipe and not route next to filler pipe! |
22nd Sep 2019 11:35am |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1965 |
My 2015 110 had an issue - fuel leaking if you filled the tank right up. Happily my independent sorted it without dropping the tank. Phew.
6th Feb 2020 9:12am |
