Home > 130 > 130 jacking points
familymad
130 jacking points
Morning all,
Has anyone a solution to the rear jacking points on a 130. You can’t get a high lift close enough due to the overhanging rear tub. Thinking of a high lift product called lift mate.
Thanks 2012 130 DCPU
1951 80" S1
1958 88" S2
Post #716658 8th Jul 2018 7:40am
As ever with these things, it depends on what you want to lift the vehicle for. On the drive maintenance, changing a wheel in the field, casting or moving a vehicle sideways?
The lift mate is designed to allow a wheel to be lifted directly and so is of limited use for two of those examples.
A decent air jack may be a good compromise for field work. A bottle or trolley jack for home maintenance or roadside wheel changing.
One of those new ARB compact hydraulic hi-lifts might fit where a traditional hi-lift won't, but it is hugely expensive.
MY USW BUILD THREAD
Post #716661 8th Jul 2018 8:07am
familymad
I love the ARB but can’t face the cost.
Would be for recovery sorry meant to say. Wondering if the lift mate clips will fit into a wolf wheel hole? Anyone used them? 2012 130 DCPU
1951 80" S1
1958 88" S2
Post #716675 8th Jul 2018 9:31am
I had a lift mate years ago and, from memory, the hooks are pretty chunky. I'm not sure that they would work with Wolf wheels.
When you say 'recovery', do you mean lifting a wheel to put stuff under it? Jackable cills would be a good addition to use with a regular hi-lift. Alternatively again, an air jack.
MY USW BUILD THREAD
Post #716687 8th Jul 2018 10:48am
familymad
Damn 2012 130 DCPU
1951 80" S1
1958 88" S2
Post #716721 8th Jul 2018 3:14pm
cartoonhead
United Kingdom 2015 Defender 130 Puma 2.2 HCPU Corris Grey
One of the reasons I went for the safari equip rock/tree sliders is that they have the jack points for a high lift. @tab.travels - Instagram
Post #717026 10th Jul 2018 3:24pm
familymad
My problem is the patriot ladder. Need it for access to all the stuff on the roof and currently uses the sill. Have emailed safari to ask if they can modify a set 2012 130 DCPU
1951 80" S1
1958 88" S2
Post #717053 10th Jul 2018 6:12pm
cartoonhead
Hmmm - that is problematic. D44 seem to be using a Hannibal ladder with the S E rock/tree sliders OK here - https://www.devon4x4.com/static/workshop/w.../roofrack/
But it looks like it's just resting on the tree slider, not sure. I've got the S E rock/tree sliders for a 130 sitting in my garage if you want to have a look at them Smile @tab.travels - Instagram
Post #717260 12th Jul 2018 7:35am
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
