Home > Td5 > Turbo Upgrade |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1411 |
In a nutshell-
A variable vane turbo alters it compression rate as you accelerate so will give you in theory more low down , but peaks sooner, giving a much smoother power curve with little lag. A hybrid has fixed compression ends, aimed at achieving higher compressed airflow. Its more suited for POWER but is compromised as its lazy at lower revs,hence turbo lag. Its all subjective, depends on what your wanting to achieve |
30th Apr 2017 11:32am |
WIL2754 Member Since: 10 Dec 2016 Location: Northamptonshire Posts: 7 |
Thanks Jim,
looks like a Hybrid would suit my needs better as it has to go up and down the A45 every day to work |
30th Apr 2017 12:38pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
Slight resurrection... what did you go for in the end?
1st Jul 2018 6:28pm |
