Home > Maintenance & Modifications > Mudstuff Defender Vent |
nickburt Member Since: 26 Apr 2018 Location: Wallasey Posts: 26 |
In other words, neither are worth getting. Think I'll build my own version of the military winterisation kit. Thanks for the reply. 1986, 127, ex Fire Tender and Ambulance |
24th Jun 2018 5:08pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 905 |
I find the standard system ok if its working as it should and you slide the vents to feet bias once the screen is clear with blower on full. The heat rises up to the side windows. I do still crack the window open for a bit in the winter on a cold damp day which helps but it's not needed for long.
However I am sure some vehicles have more damp inside with various leaks than others which obviously doesn't help the condensation situation. Also make sure the wing intake is not holding any water and the drain is clear. Mike |
24th Jun 2018 5:56pm |
Agreed Mike c
I'm OK with the standard set up, was just looking for improvements, but only if they're worth either spending the money on, or making the effort. My 127 has as a few holes that let as much air in as they do water, so I get the worst, and best, of both worlds .... water gets in, but there's plenty of ventilation I'm going to be stripping my bulkhead in situ in September, so was just looking at doing as many jobs as possible while it's in bits and improving the standard blower system air flow is one of them. Rebuild the heater box (with new matrix and seals etc), new ducting and a later dash top with the wider air vents, so the natural progression was to look at fitting side vents too. 1986, 127, ex Fire Tender and Ambulance |
24th Jun 2018 7:03pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2547 |
Been happy with my home made ones for best part of seven years now, work well. Limited by the volume of air moved by the blower but a massive improvement on the standard setup.
24th Jun 2018 9:00pm |
Any pics please? 1986, 127, ex Fire Tender and Ambulance
24th Jun 2018 9:31pm |
Pics and info here:
http://www.retroanaconda.com/landrover/201...demisters/ |
24th Jun 2018 10:44pm |
Nice one, thank you. 1986, 127, ex Fire Tender and Ambulance
24th Jun 2018 11:42pm |
That makes sense nickburt, good luck with your rebuild
I just think sometimes it's all too common to criticize some aspects of the defender (not that you did) when things just need maintenance/renewing or a different technique in the use of whatever it is in question. Some bolt on stuff is just overpriced tat imo and not necessary. Obviously there's also genuinely useful things that can be found as well Mike |
25th Jun 2018 10:18am |
Indeed Mike c, maintenance being the operative word 1986, 127, ex Fire Tender and Ambulance
25th Jun 2018 7:21pm |
