Home > Maintenance & Modifications > Spare Wheel Lock |
toby9946 Member Since: 23 Sep 2015 Location: Hampshire/London Posts: 96 |
Just in case anyone else is wondering like I was the Sawtooth spare wheel lock on eBay with the "FortXLocks" also fits on the Dual Finish Alloys........
http://www.ebay.co.uk/itm/Sawtooth-Wheel-L...SwgQ9Vu~Iz Click image to enlarge Click image to enlarge -2015 Defender 90 XS Landmark- |
17th Oct 2015 2:20pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16857 |
I doubt that it would fit any of the steel wheels since the hole in the middle of a steel wheel is much bigger.
I don't see why the same locking principle shouldn't be adopted though. |
21st Oct 2015 3:03pm |
That's what I call a tasty discreet update with a purpose.
Would the entire item, including screws, bolts, and the lock be rustproof? It is very exposed to the elements of course, and you don't want to face the situation where you can't turn the key anymore due to a rusty lock mechanism. I think the looks are perfect, so when I come home again end this week, I will check if it would be possible to fit on my Aussie Kaymar wheel carrier. Eric P.S. There is some conflicting info in the posts. OP says that the version for Sawtooth also fits the Dual Tone wheel. Then Sadi says that there is one for Boosts/Dual Tone and another one for Sawtooths. ?????? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
21st Oct 2015 6:26pm |
Sadi Member Since: 23 Jul 2015 Location: Windhoek Posts: 334 |
Hi Eric,
The seller acknowledged there to be a different sized washer for the 2 mentioned wheels. My vehicle will have steel rims - but I received a complete Boost wheel as a gift from a friend. I will thus replace the steelie spare (store it in a cool dry place) and hide the difference beneath a Defender specific cover. |
21st Oct 2015 8:00pm |
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 |
Are these still available anywhere? The original seller does not appear to be contactable anymore. I would want one to fit a Dual Alloy wheel on my Puma 110 USW. Alternatively are there any other similar products on the market?? Discovery 4 HSE
Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
17th Jun 2018 6:28pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4789 |
Unable to get these anymore but Brendan a forum sponsor does a great lock for the spare wheel. 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
17th Jun 2018 6:58pm |
As above, 4x4overlander Ray
17th Jun 2018 7:00pm |
Sent a message to maker/seller of these on Ebay. Got a response today: "due to illness he has stopped making them for a while but intends starting again when feeling better" so if interested keep watching Ebay. Discovery 4 HSE Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
18th Jun 2018 8:17pm |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
I had to renew a locking nut on one of my wheels and was surprised as to how few combinations of lock nuts there are. The actual letter is stamped on the nut so all the scrotes have to do is have a selection and nick my spare.
SO Here is a spare wheel lock I just made using an SAS caravan corner steady lock, an M36 steel washer and some screwed rod. The yellow one is a prototype which shows up clearly and the black one with yellow ring is the finished article. Pretty much as the one on the first post. SAS lock £21 M36 washer 50p screwed rod nuts and washers approx £2.5 Welding one rod. total materials inc paint and lacquer £26. |
20th Jun 2018 12:19pm |
BobT Member Since: 13 Jan 2017 Location: North Yorkshire Posts: 110 |
I have one of those too, looks good and not only secures the spare but shows you take security seriously so might put someone off having a go at your Defender other than nicking the spare. |
24th Mar 2019 7:25pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2520 |
Click image to enlarge Click image to enlarge Click image to enlarge Hi To answer an earlier question this kit can be modified to work with a steel wheel. Instead of mounting the main part to the outside of the wheel carrier, I cut a hole and fitted from the inside, spaced out to suit the wheel thickness. I then cut a disk (as best I could) from a sheet of alloy with neoprene stuck to the back to prevent scratching and allows a little give when installing the padlock. I hope that this helps someone. Cheers Mark |
25th Mar 2019 9:57pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Looks good Mark. What are the shiny dots around the edge of the wheel rim?
26th Mar 2019 12:20pm |
Hi Kmac
The silver dots around the wheel are unpainted rivets, not sure if they are practical or just decorative. Cheers |
26th Mar 2019 10:12pm |
Andy T Member Since: 25 Aug 2017 Location: Bucks Posts: 216 |
In case anyone's interested, I'm going to list one of these for sale... 2011 2.4 White 110 CSW LHD
1998 300TDi Wolf TUM 2015 2.2 Corris Grey 90 2009 2.4 Alaska White 110 Commercial - gone 2006 TD5 Barolo Black 90 - gone 1995 TD5 Green 90 - gone 1984 2.25 Marine Blue 88 |
7th Nov 2023 6:50pm |
