Home > Technical > DEFENDER TD5 CLUTCH REPLACEMENT |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 704 |
It could be that either your master or slave cylinder is faulty, any signs of fluid loss?
If you have the old style coil springs on the clutch pedal, you can change to the softer type, it made a big difference on my TD5. http://www.defender2.net/forum/topic53952.html 2005 Td5 110 Hardtop 1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
18th Jun 2018 9:13am |
Carolos1973 Member Since: 06 Sep 2013 Location: Limassol Posts: 7 |
Many thanks!!!
18th Jun 2018 11:07am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 539 |
when the clutch is worn it can give a heavy pedal, but also worth checking if you have the pedal box mod done as mentioned by Harry.O
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt |
19th Jun 2018 12:40pm |
