Home > Technical > Horn question
mk1collector
Horn question
Does anyone know if td5 defenders came with the wiring for twin horns? I think they should mount one behind each headlight but before I start trying to dig down to find the plug I wondered if anyone knew. Thumbs Up
Ray Ray
My build thread
Post #712204 13th Jun 2018 4:17pm
rallysteve
United Kingdom 1984 Defender 90 V8 Petrol PU Caledonian Blue
My 02' has wiring in place for twin horns (a 2way MQS connector if i recall). One is behind each front panel.
Steve 02' 110 TD5 Double Cab
84' 90 3.9 V8 Caged Pickup
Post #712207 13th Jun 2018 4:45pm
mk1collector
That’s just what I wanted to here thanks Thumbs Up I’ll start digging Mr. Green Ray
My build thread
Post #712211 13th Jun 2018 5:08pm
jst
Confirmed, yes they should have wiring there Cheers
James
www.4x4adventures.co.uk
110 XS Utility
90 tdci Softtop
Post #712212 13th Jun 2018 5:09pm
mk1collector
Perfect Thumbs Up Ray
My build thread
Post #712213 13th Jun 2018 5:11pm
mk1collector
Ok, another question. Does anyone know the wire colours for the o/s (drivers side uk) horn. I’ve had a good look and there are a pair of wires disappearing back up towards the wheel arch that are black and green/white. They are pretty stuck so if they are the correct wires I’ll drop the wheel arch cover Big Cry Ray
My build thread
Post #712247 13th Jun 2018 9:01pm
rallysteve
They are the side repeater wires, hence why they are resistant to coming out Laughing
I cant remember from memory but i think it is either purple/black or purple/brown. Should be down towards the headlamp 02' 110 TD5 Double Cab
Post #712264 13th Jun 2018 9:45pm
VVS210
United Kingdom 2002 Defender 110 Td5 DCPU Bonatti Grey
i just got one of these... Very Happy
Post #712265 13th Jun 2018 10:08pm
sako243
United Kingdom 1995 Defender 110 300 Tdi CSW Alpine White
Well I would start off on an I've got a bigger one but I know someone will better me. I've just mounted the twin trumpets inside my 110, just need to plumb in the air supply now. Doing a bit of a rearrangement so that the tank won't continually bleed out air via the Ashlockers.
Can get a photo tomorrow. Ed
07 Range Rover L322 3.6TDV8
95 Defender 110 300Tdi
Post #712269 13th Jun 2018 10:35pm
mk1collector
There was another pair of wires going in the same direction that I’d convinced myself were the repeater wires but I’m usually wrong Rolling with laughter there were no other spare wires by the headlight so it must be one of the two pairs that went back towards the arch spat. I’ll have another look tomorrow Thumbs Up Ray
My build thread
Post #712274 13th Jun 2018 11:00pm
mk1collector
That looks fancy Mr. Green Ray
My build thread
Post #712275 13th Jun 2018 11:02pm
mk1collector
I was thinking of a train horn or a Tour de France horn but I’ve got a spare defender standard one in the garage so that will do for now. Ray
My build thread
Post #712277 13th Jun 2018 11:04pm
sako243
I have several but I keep killing them and they seem pathetic. What really took the biscuit was a police patrol car realising at the last minute he didn't want to be in the filter lane. Apparently a white 110 isn't big enough to see right next to him (I mean literally next to his door). Thankfully I managed to avoid a collision but from that moment started investigating better alternatives.
Then sourced a power steering relay box and pair of trumpets for the princely sum of £50 so a plan was hatched. Given I've already got an on board air setup (air con compressor style not weedy electric one) for the Ashlockers I don't think I'll struggle for air... Ed
Post #712278 13th Jun 2018 11:09pm
sako243
They're ******* loud (technical term there)
 Ed
Post #712557 15th Jun 2018 11:21pm
mk1collector
Mr. Green Thumbs Up Ray
My build thread
Post #712559 15th Jun 2018 11:37pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
