Home > My Defender > My 110 MILLIE.
Page 13 of 62 <123 ... 121314 ... 606162>
L110CDL
Many thanks Seriesonenut and Rosco Very Happy Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #710808 4th Jun 2018 8:43pm
HK07
England 2007 Defender 90 Puma 2.4 HT Cairns Blue
Hk07
Clayton how did you get out of it/back in it, with it that close to the car along side?
 2007 90 Puma - Love it - Best car I have ever owned.
1989 Ninety 200tdi - Love it - Second best car I have ever owned.
1951 80" Series 1 - Love it - Third best car I have ever owned.
Post #710832 5th Jun 2018 3:33am
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I really like the galvanised front bumper
Post #710837 5th Jun 2018 6:49am
L110CDL
^^^ thanks Nigel Thumbs Up
HK07
Looks are deceiving, there is enough space to fully open my door without hitting the wives car Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #711329 7th Jun 2018 8:28pm
L110CDL
With all the talk of the nipple's on the prop shafts i had to go out and check to see what i had got or not got Wink at the same time i decided to grease the front and rear props, i got a good amount in Very Happy
The front prop has the 3 nipples Very Happy
The back prop has 2 nipples, is this correct ? ?
I have not got the Castrol grease yet, but it is on the list to get Very Happy
http://www.defender2.net/forum/topic61560.html 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #712116 12th Jun 2018 8:42pm
Front and rear should have three each, one per uj and one for the slider.
Post #712131 12th Jun 2018 9:29pm
L110CDL
Thank you blackwolf, will have to further investigate the back prop shaft Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #712136 12th Jun 2018 9:49pm
Where was the missing one UJ's or slider? I'm guessing the latter but could be wrong.
I had one missing on the front on a UJ and one missing on the rear on a UJ.
The front slider nipple was not loose but appeared only half threaded on, and appeared as if it was fitted like that too.
I cannot have any way of knowing, if I lost them or they were ever fitted on the .UJ's.
My guess is I lost them, at some point, somewhere.
There was talk that some were missing from the factory though! Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
And if You Love the Country, then we’re on the same side ~
I got’ love for Britain, I got’ British pride’. 🇬🇧
Post #712145 12th Jun 2018 11:11pm
L110CDL
When i had finished my T ( grub ) i went out and had a good look to see if i could find the missing nipple Very Happy after all off 10 seconds, i found it, so all greased up now and well happy that i have 3 nipples on the back prop as well as the front one Mr. Green 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #712253 13th Jun 2018 8:16pm
Best way, if they’re missing is when you could have a massive risk of ingress. So all good, least you won’t have to mess with them Thumbs Up Diesels Lives Matter. ⛽️🛢️👨‍🔧🧰⚙️
Post #712282 13th Jun 2018 10:50pm
L110CDL
On Friday i left home at 5.50am Very Happy and drove just over 400 mile round trip, to get the next mod to Millie done as i have wanted this one before winter comes Wink here she is after i got back home about 4.30pm ish as i had a few delay's on the motorways Rolling Eyes .................................
A clue i hear you say, so here it is ..........................................
Yes i drove up to VGS to have Dav put and wire in the heated windscreen as i have not time to do this and he showed me how to work it all ok Very Happy
What a great chap Dav is, a really nice chap and the 2 hours that i was there went by very quickly Wink
So i am waiting to test it when the weather changes, all in all i had a great day Mr. Green 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #712878 17th Jun 2018 7:04pm
mk1collector
A great mod and well worth doing Thumbs Up I finally wired mine up before last winter (even though I put the screen in about three years ago) and it was great with no more scraping ice off in a morning Mr. Green Ray
My build thread
Post #712890 17th Jun 2018 7:34pm
L110CDL
Today i had a chance to change over my light covers in the pick up part as they were getting worse, one more than the other Rolling Eyes .................................
After taking the covers off, the one on the N/S was the worse as the way i carry/fix my laid that goes in the back had worn it through Sad ............................................
So what i had done is got 2 more covers, it is hard to get a pair of covers that the one on the O/S has not got a hole in for i assume for the electric wire's to go through Rolling Eyes
I had painted them and my idea was to put wood on them as just putting metal on again would ware and the laid would slide from side to side still, with the wood on it should dig in a little and not move very much and if/when it does, the wood can be changed with no problems Wink
The first pic is with the bottom lip still on which has to come off as i have got CP all in the back ................................
With the lip cut and smoothed off .................................................................
The next pic is them fitted in and i ran some clear silicon around the edge's to keep them water tight, this has worked a treat as i have always used this method Very Happy ..........................................
The last pic is to show you how the laid is carried/fixed when not in use ..............................................
The change over went like a dream and i'm very pleased with the outcome Very Happy Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #712891 17th Jun 2018 7:35pm
L110CDL
That's what i thought Ray after all these years scraping off the ice and snow Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #712893 17th Jun 2018 7:36pm
Procta
Beefed up front ends like L110CDLs and mine, make people think twice about pulling out on you at the last min. Very Happy Many times i have had the Shocked look at me, when people have took their chance and realised i am not slowing down. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #712928 17th Jun 2018 9:09pm
