Home > Maintenance & Modifications > Oil in Handbrake DRum |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19568 |
Can't help identify exact part but this maybe helpful:
https://www.landroverworkshop.com/ Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
5th Jun 2018 10:37pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
Here you go https://www.landroverworkshop.com/diagrams...ge_45155#7
It may also be worth replacing the flange too as that may be a cause, depending on age of your vehicle. Item 9 in the diagram Another check worth doing, with the handbrake off (vehicle chocked) push the drum up and down to look for play. If there is, the bearing needs replacing too and is what will be wearing the seal out (item 4) |
9th Jun 2018 6:06pm |
