Home > Td5 > Dropped Injector Copper Seal in Engine |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
I was putting the new injector seal kit into the injector base and the copper ring fell into a hole between the two injectors. I cant seem to find it. Will I have to take the head off? Very Frustrated!!!
Click image to enlarge |
19th May 2018 10:23pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1566 |
Double post
19th May 2018 10:27pm |
Its the other one
19th May 2018 10:28pm |
Long needle nose pliers and take the rest out you should be able to get it. You can try a clump of sticky grease on a bit of bent wire to pick it up, just clean up after.
19th May 2018 10:31pm |
Do you know where that hole leads to???? I cant seem to see it.. I have a super bright LED flash light too.
19th May 2018 10:33pm |
My laptop is in Work with all my diagnostic gear and manuals, if you look in the manual it’ll give you a water and oil flow diagram. I’m not sure where you mean it’s fallen exactly, but the head is in two parts head and cam carrier.
Reason I say check the injector port as I’ve dropped them before and 9 times out of 10 it falls back into the injector socket, can be quite hard to tell if there’s oil and carbon build up. |
19th May 2018 10:38pm |
I'm quite frustrated Its not in the injector port. I saw it fall into the other hole.
19th May 2018 10:40pm |
Try a bit of wire fishing in the hole
19th May 2018 10:46pm |
see your next post
Where does this hole lead to Last edited by dorsetsmith on 21st May 2018 12:21pm. Edited 5 times in total |
20th May 2018 6:14pm |
It's the hole between the injectors.. I tried fishing it out with a wire... I had it.. Then it dropped again. I don't know how deep it dropped this time
20th May 2018 6:27pm |
20th May 2018 6:28pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5736 |
I'd hope there is lip in the injector hole to stop the washer dropping through any further. 1999 Defender TD5 110
21st May 2018 12:17pm |
