Home > Expedition & Overland > Shelf/storage in rear of USW |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16871 |
Buffalo board, perhaps.
https://www.google.co.uk/search?q=buffalo+...mp;bih=705 |
16th May 2018 3:59pm |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
That looks like the stuff. Ta very much.
Will need to work out what size sheet and I can spend an afternoon cutting and fitting. I'll post some pics once I'm done. Thanks Keith |
16th May 2018 4:10pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 559 |
I did this and used j bolts and made some socket type nuts that sat flush with the top of the board. The hook of the j hooked into the original lashing points meaning I can secure the board properly but remove it and leave no trace of it ever being there
16th May 2018 5:39pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2547 |
Often sold as phenolic plywood. £40 or so should get you an 8’x4’ sheet of 18mm stuff from your local timber/builders merchant that is suitable for your use.
You can get much higher quality (i.e. more water resistant) stuff for lining trailers and the like but it’s double the price, or more. |
16th May 2018 7:03pm |
I managed to source a sheet of 18mm buffalo board, cut the sheet to size and mounted it in the rear loadspace. Contemplating using the large off cut to make a platform on the roof rack.
Click image to enlarge Now to source some j hooks to anchor it fully. I'm quite fancying the cargo rails that Mud and 4x4 overlander sell to mount on the top and let me anchor the fridge down, or have I missed a smarter idea? Keith |
22nd Jun 2018 7:02pm |
