Home > Technical > conversion to disc brakes |
Bert@E Member Since: 08 Jan 2016 Location: amsterdam Posts: 63 |
hello,
can i put a rear axle of a defender 300tdi under my 90 (1986) ? |
23rd Apr 2018 12:04pm |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5084 |
Yes, you can. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
23rd Apr 2018 12:35pm |
with major changes?
23rd Apr 2018 1:05pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 832 |
No major changes as they are both coil sprung and have the same track. The 110 rear axle from a 300tdi will have the stronger Salisbury diff, should be the same ratio though, but worth checking.
23rd Apr 2018 2:53pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6037 |
Salisbury into a 90 needs the prop shortening by 1 3/4" (43mm ish) but as said, ends up quite short and prone to vibrations.
a 4 pin diff with HD shafts (or even a later Rover type 110 axle) will give similar strength to the salisbury, albiet without the weight carrying capacity. |
23rd Apr 2018 7:47pm |
Wheel Member Since: 29 May 2014 Location: Essex Posts: 232 |
Sorry to hijack this thread Bert,
I have a 110 Salisbury axle that I was going to fit to my future 90 trayback for off roading. I knew I'd have to shorten a prop so was going to use a shortened Disco II front prop due to it being a double cardon which I thought would be better for vibration and articulation as it will be running a 5" lift. Can anyone offer any advice on this please, i.e. is this feasible and will it work as I'm now thinking the diff nose will be too long for a decent prop angle even with the double cardon ?? Thanks, Mark |
24th Apr 2018 4:13pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
If you are going to build a trayback, why not put the axle a bit further to the back? Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
24th Apr 2018 8:03pm |
voorfrank Member Since: 06 Feb 2017 Location: Schiedam Posts: 37 |
You can swap Land Rover axels from a Defender 90 and Range Rover and Discovery 1 without modifications
Only when you install a salesabury axel you have to shorten the propshaft. |
25th Apr 2018 11:09am |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1568 |
Unless it’s a 300 Tdi Discovery axle and you’ll need to change to the 4 bolt drive flange instead of the rubber doughnut style on the diff.
25th Apr 2018 5:07pm |
There is a brake pressure restrictor for the rear axle on the right chassis leg or am I mistaken? Are they the same for drum and disc brakes? Roel
25th Apr 2018 5:40pm |
