Home > Puma (Tdci) > O/S side light and rear light not working after change |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 323 |
Fitted the other light and no issues - everything works.
Checked the fuse for the side light and that's intact. Stripped the connection on the light that doesn't work and just connected the side light - nothing. Rear light also still not working. So if the issue isn't at the connection, does anyone know what the side light and rear light share? |
10th Apr 2018 1:02pm |
Sooo....went over all the fuses again and worked out the fuse diagram is upside down.
Found the shorted fuse. Replaced and it went as soon as I turned the lights on. Not knowing anything about electric, why would this be happening? |
10th Apr 2018 1:49pm |
Fixed...was touching something it shouldn't have been.
As a complete beginner I hope this helps others who are just learning about their cars. |
10th Apr 2018 2:00pm |
