Home > Td5 > Battery Compartment, Fuel Gauge & Internal Lights |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I didn't seal up the compartment, I simply moved the ecu onto the bulkhead between the front seats.
Their is a post somewhere about it, but long story short, un-plug the ecu and pull the cables back above the tx/gearbox's and drill behind the tx box access panel into the cabin. Then move the power cables etc up to the cab and mount the fuses up there too to as its one way thieves steal TD5's If you can't find any posts about relocating the ecu their is loads just google. I will take pics of mine. It is very simple to do. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
1st Apr 2018 1:14pm |
RANGER1312 Member Since: 04 Feb 2018 Location: Fylde Coast Posts: 125 |
Thanks gazman, I'll have a Google later!
Please can anybody advise regarding the rear window wipe, I presume it is meant to be illuminated? Can you change the bulbs in the switches or is it more likely to be a power issue considering 2 switches now haven't worked? |
2nd Apr 2018 11:49am |
I've only ever had a harrazr switch apart but I'm sure it was a led on a mother board not a bulb 2014 - current ..... 2003 defender td5 90 (my car)
2nd Apr 2018 12:18pm |
I'll try and take a look at the wiring and see if I can see anything, thanks for your advice gazman!!
2nd Apr 2018 9:41pm |
