Home > Technical > Whining/Groaning from Front when steering.... |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 719 |
If you have power steering you can get a moaning noise, but only on full lock. You are advised not to maintain full lock due to the pressure in the PS pump. If you are getting moaning at other times when steering, then check the PS fluid level, but I would suspect a deteriorating pump.
I am certain others will provide more expert advice. |
26th Mar 2018 12:01pm |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
If you get the noise on full lock, it's probably the tyre rubbing the radius arms.You can adjust this with the steering bolt. a defender from 1984 pretending to be a puma with a touch of Range Rover
26th Mar 2018 12:18pm |
PK1 Member Since: 19 Oct 2012 Location: Gloucestershire Posts: 96 |
On mine it was the wife Defender 110 TDCi XS SW
Range Rover Sport HSE |
26th Mar 2018 12:43pm |
Srry pk1 there are no known fixes for this problem a defender from 1984 pretending to be a puma with a touch of Range Rover
26th Mar 2018 12:54pm |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
It can be heard when stationary also, so I could rule the tyre rubbing out I think, It sounds from what is being said here its the power steering fluid or pump......Maybe.....Seems to be worse in reverse and near full lock, but that could be just a coincidence.....
JD 2008 TDCi 2.4 XS CSW |
26th Mar 2018 1:56pm |
Try running the engine without belt and see if the noise disappears. It could be the power steering Or perhaps water pump. a defender from 1984 pretending to be a puma with a touch of Range Rover
26th Mar 2018 2:07pm |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 168 |
is it this
http://www.defender2.net/forum/topic39086....+hydraulic a groaning noise when tuning left when cold - if so, apparently normal and from resonance in hydraulic pipes - mine does this (MY2015) |
26th Mar 2018 9:53pm |
Turns out the fluid level was low due to a small leak in the steering box, garage topped it up for free and will replace the steering box for about 250 quid next month when it’s due for MOT and service.......
27th Mar 2018 9:20pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1613 |
Was it only on full lock or all the time |
28th Mar 2018 12:07pm |
