Home > Maintenance & Modifications > Heavy duty or single piece half shafts? |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
My standard 110 drive shafts with the separate drive flanges lasted about 2 years. LR replaced them under warranty with the late-spec one piece shafts, so far they’re still going strong after another 2 years.. happy so far! 2014 Keswick Utility 2.2
11th Mar 2018 9:00pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I'd replace with the one-piece shafts if I could, one less place to have slop.
Sadly I have a Salisbury back axle, so I need to replace that as well to swap shafts! |
11th Mar 2018 10:03pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16809 |
In 220,000 miles I got through 2 sets of standard 2-piece, 1 set of Ashcroft HD, and am now running genuine one-piece. The latter are favourite but, strewth, do they cost a lot!
11th Mar 2018 10:55pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
I have 1 piece half shafts on my 90. 130k miles so far and still fine 2002 90 Td5 Station Wagon
11th Mar 2018 10:59pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6026 |
I think, I'm not 100% sure, that the 110 and 130 have a different part number to the 90 spec one piece shafts, But I was wondering if disco 1 piece (or 90) shafts can be fitted to a 110? (With a Rover/P38 diff axle ,naturally)
Or are they not strong enough? |
12th Mar 2018 7:12am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3459 |
I went one piece and the clunking noises have stopped and not returned after 10k hard miles. Previously was going through a set as a service item every 2/3yrs. 1951 80" S1 2.0
12th Mar 2018 7:25am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
Black wolf, your Ashcroft shafts that you wore out, where and how?
spline end on drive member? was that std drive members or ashcroft ones? on mine i am running Ashcroft shafts and std drive members, i just change the drive members every year. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
12th Mar 2018 10:00am |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 635 |
Any thoughts on where is best value to buy on line the 110 single piece shafts?
12th Mar 2018 12:57pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Not seeing a lot of love for the two piece setup either standard or HD. So, with that in mind, what's the most cost effective way to get 1 piece shafts? I really don't want to go down the new LR route as my pockets are not nearly deep enough. Who makes a single piece unit that is also a GOOD unit, or is second hand the way to go? Plenty Disco half shafts on eBay, is this a viable long term fix? Also, does any 1 piece Disco shaft fit?
12th Mar 2018 2:37pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I had 24 spline single piece in my CT Disco. I broke some due to my Detroit locker.
Also they don't like bearing play. I have a feeling that the 2 piece shafts are stronger as the one pece shafts broke at the flange side and my 2 piece shaft break at the diff side most off the time. I have Aschroft with HD flanges in the rear off my 90. and they last. I put gear oil in the caps regularly. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
12th Mar 2018 2:43pm |
I had a water/mud ingress problem which annoyingly wrecked an ATB and caused fretting to the diff end of the shafts. Although usable I replaced the with one-piece when I repaired the axle. |
12th Mar 2018 2:58pm |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
If you have a 90, second hand disco 300tdi shafts are fine. They are a slightly narrow diameter that the two piece shafts but the same diameter where the seals run. It needs to be from a 300tdi disco or 300tdi defender. The disco 200 used a different halfshaft and early ones were 12 spline diffs. I have run them in five different Defender td5 and Puma 90 I have owned over the past 12 years with no issues. They were fine for the disco v8 back then. You could probably pull a pair out of a scrap 300 disco for a tenner! |
14th Mar 2018 6:13am |
cheers, so there was no issue DM end then. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
14th Mar 2018 7:54pm |
No a little wear but quite serviceable still.
14th Mar 2018 10:12pm |
