Home > Wheels & Tyres > How to set torque setting - steel wheel nuts
seriesonenut
Hi
Daft question but cant get my head around it. I want to fit my Wolf Rims for a couple of months replacing my XS alloys. I have a new set of steel nuts and know the torque should be 170 lbs ft.
My torque wrench only goes to 100 lbs ft.
Any suggestions to make sure I have got them tight enough? I thought of doing this in two steps 100 then 70 but surely the second time it would be already past the setting and not therefore work? Banging Head
Thanks 2010 XS USW
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #687023 16th Feb 2018 5:59pm
Buy a bigger torque wrench!
Either that or a torqje multiplier, your only options really.
Post #687025 16th Feb 2018 6:03pm
I'm wondering if torquing to 100 and then tightening a set number of degrees would do it.
Is there a calculation for the extra 70, or would it be a applicable to take that figure from a similar setup?
I'm happy to torque mine to 100 & then reset to 170 & report the additional degrees.
If several members were to do it would the figures be that different?
The real answer has already been given though Rolling Eyes
Post #687030 16th Feb 2018 6:22pm
seriesonenut
Hi
I thought I knew the answer but I was trying to avoid 'another bill'. Given its a fundamental safety matter no time for penny pinching. That said I could fit then pop to my local tyre garage and ask them to torque them up for me to get mobile.
All I need now is a 'vat off' offer from Machine Mart Whistle 2010 XS USW
Post #687037 16th Feb 2018 6:38pm
There must be a thread on here with regard to the best torque wrenches/best prices...never found MM vfm for anything.
Nip along to Halfords, some of theirs can be good quality at a reasonable price.
Post #687042 16th Feb 2018 6:48pm
Gareth
England 2003 Defender 90 Td5 CSW Oslo Blue
Halfords torque wrench has served me well for years. You will use it again so it’s a good investment. No point in short cutting safety. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
1968 S2a 88 aka Bob
2014 Jaaaag F Type 3.0 Supercharged.
Post #687045 16th Feb 2018 6:55pm
LR90XS2011
once was stuck like you and used a bathroom scales or if you have one a spring balance for example a 2 ft wrench push or pull until you see 85 lbs, if that makes sense, obviously the length of your wrench alters the maths. DEFENDER 90 TDCI XS,
Post #687047 16th Feb 2018 7:26pm
Hands up who's fitted a wheel without using a torque wrench and not died as a result? Darren
Post #687066 16th Feb 2018 8:30pm
ericvv
Re: How to set torque setting - steel wheel nuts
seriesonenut wrote:
Hi
Thanks
Wrong, correct Wolf rims torque is 170Nm, which is equal to 125lbs ft.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #687073 16th Feb 2018 8:48pm
seriesonenut
Ahh thats a help (I think)...... 2010 XS USW
Post #687075 16th Feb 2018 8:52pm
williamthedog
Guilty your honour, on more occasions than I can remember Whistle
Post #687077 16th Feb 2018 9:00pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
It’s 170 NM not lbs ft Exclamation 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #687095 16th Feb 2018 10:40pm
seriesonenut
Yes my mistake. Still need a bigger torque wrench though Whistle 2010 XS USW
Post #687097 16th Feb 2018 10:41pm
Mash
Halfords have a good range if you have a trade card. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #687099 16th Feb 2018 10:44pm
seriesonenut
Don't have a card but they seem to have a better range. I really should buy a better wrench mines years old in any case. I just had a plan to do a wheel swap tomorrow then thought about setting the torque hence the question. 2010 XS USW
Post #687103 16th Feb 2018 11:00pm
