Home > Wheels & Tyres > What size?! |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1526 |
what engine is in yours?
is the t box standard? 205 80 16 7.50x16 235 85 16 265 75 16 all standard lr sizes. small to tall and thin to wide. |
12th Feb 2018 7:37pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
As above James
12th Feb 2018 7:38pm |
The size you need is either 235/85 or, possibly, 7.50 x 16 if you're using standard steel wheels.
If you're using standard LR alloys then 265/75 is also a common size. I think the difference in mileage between the sizes would be marginal, at best. Tread pattern is likely to make more of an impact but even that won't be huge. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Feb 2018 7:40pm |
barrowg Member Since: 31 May 2016 Location: Surrey Posts: 232 |
I have a 1990 200tdi with the lt77 gear box if that helps? |
12th Feb 2018 8:10pm |
Looking to get alloys instead of steels so I guess it’ll be 265/75 then |
12th Feb 2018 8:11pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7686 |
265.75R16 or 235.85R16 for alloys on your tdi would work well. both near as the same OD, one set just 30mm wider. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
12th Feb 2018 11:08pm |
perfect thanks alot great help
12th Feb 2018 11:13pm |
iamthehough Member Since: 24 Mar 2018 Location: scotland Posts: 5 |
ive got a similiar issue
24th Mar 2018 10:25pm |
