Home > Td5 > Middle row seat options |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2058 |
Intetested. I want to do similar. Exmoor high backs but fitted to the 60/40 seat bases. Should be able to do that with some fabbing and welding.
Could always strip the 60 seat off the frame and pick up another 40 seat, then fit in place. Could work. |
11th Feb 2018 6:05pm |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
I have the Exmoor Trim Premium High Backs in mine.
I wouldn't buy them again nor recommend. |
11th Feb 2018 8:29pm |
Why so?
11th Feb 2018 8:43pm |
They aren't compatible with child seats (Exmoor Trim no longer advertise them as such and did offer a full refund when this issue first arose, so full credit to them).
The side wings (for want of a better description!) on the bases are too firm, high and wide to allow adults to sit in them. I will stress that Exmoor Trim as a company where superb to deal with and I love their front seats. I just wouldn't recommend these ones |
11th Feb 2018 8:54pm |
Thats a shame! They are what I wanted, ill have to have a look in person and have a seat.
How not compatible with child seats? Thats one thing I will need eventually. Not sure what other options there are now lol |
11th Feb 2018 9:04pm |
If you're ever in the area you're welcome to have a look/ sit in!
They look great and the back rest is adjustable which is nice. Child seats wont fit on the base due to the raised "wings". I will probably have a trim specialist rebuild the bases to be flat, but if I did it again I would fit Puma seats in the middle. |
11th Feb 2018 9:07pm |
Thanks! I have read about the Puma seats but read much the fit isnt great as they are rather large
11th Feb 2018 9:12pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 897 |
Two front seats and a cubby for the rear passengers
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
12th Feb 2018 4:05pm |
bluebottle Member Since: 08 May 2015 Location: Not in my Landy enough! Posts: 705 |
That looks good, can they fold to take a long load and how hard is it to fit them to the seat box?
12th Feb 2018 11:52pm |
Me too! Looks like you used the original frame? Think you could fit a middle seat instead?
13th Feb 2018 12:08am |
The seat backs do fold down just like any regular front seat, however you have to pull the head rests off then it can flip up to give more space. I did it once. Very fiddley and bit of a PITA
As for using the seat frame that is what I did. I had a 60/40 slipt rear seat and bolted them together when I attached the front seats onto it. Using the front seats is very useful for under seat storage access, just pull up the seat base and there is your stuff. Yes you could in theory put a small middle seat in place of the cubby. 👍 Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
13th Feb 2018 3:36pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 755 |
I like the front seats in the back modification, might give me an excuse to upgrade the fronts..........
13th Feb 2018 8:48pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I do currently have the 30/30/30 rear seats, (the original rubbish square ones) but they're tired and desparately need replacing. I am now thinking that a pair of tired TD5 front seats would be both cheaper and better than a pair of exmoor high backs! And then I could put a cubby/sub enclosure in the middle....
First off I need to replace the middle row floor upstand, as it's all gone crumbly.... |
17th Feb 2018 2:39am |
I guess as long as you can get the spacing correct, there's no reason you couldn't fit a front row middle seat in there? |
17th Feb 2018 2:40am |
