Home > In Car Electronics > Interior light timer
Will17will17
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Morning all,
When I open the driver door on my 90, the interior light only stays on for 3-5 seconds, if I do the rear door or passenger it's for alot longer (approx 10-15 seconds)
I have had a quick search and can't see anything similar, I'm assuming they are a set time and it cannot be altered, any help appreciated: something small but quite annoying 😁
Thank you
Will
Post #678082 13th Jan 2018 9:12am
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Will
just to clarify, this is your 2015 90 and do you mean if you open a door - and keep it open - the light goes out after a few seconds?
There is a timer, to save flattening the battery I assume, but it is more like 10 minutes or so.
Or do you mean when you close the door, the light stays on for a few seconds?
If you clarify the exact problem, it will bump the thread and someone will know the problem Thumbs Up
Post #678146 13th Jan 2018 3:19pm
JWL
With the Td5's you can access the Alarm system with a Nanocom or the like and alter the seetings with that including the interior light delay.
Post #678149 13th Jan 2018 3:23pm
Will17will17
Thanks apt, Sorry For any confusion, yes my 2015 90,
I meant if I open the drivers door (climb in) then shut the door the light stays on for 3-5 seconds, however if i do the same with the passenger or rear door it stays on for 10-15 seconds.
Thanks
Will
Post #678215 13th Jan 2018 7:35pm
grafty99
If the door is closed and the interior light is on, turning the ignition on fades the lights off immediately Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #678217 13th Jan 2018 7:41pm
Functions are controlled by the AS10, can be adjusted with Nanocom as suggested above on a TD5 but applies or Pumas also.
Are light fixtures the same? It could be driiferent draw on each fixture that makes a difference.
The lower the draw the faster they go of normally, so LED if fitted being very low current draw will go off much quicker than a regular incandescent bulb.
Just a thought, but possible wrong. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #678239 13th Jan 2018 9:41pm
zsd-puma
As above the 10AS alarm unit controls it (even if you don’t have an alarm the actual alarm is still there)
I would clean up the door switch’s and give the screws a tweak and see if that’s makes a difference.
Post #678293 14th Jan 2018 4:16am
grafty99
The OP said that they turn off much sooner when the drivers door is closed, the only reason that the lights would fade off quicker is because the ignition is being turned on. The fade delay time isn't selectable, you can only turn the function (smart interior lights in the menu) on and off.
When the ignition is on there is no delay before fading. If you close a door with IGN on the light fade out immediately where as if IGN off the lights stay on for 15 seconds.
The ignition over rides the delay function and will cut the delay short and the lights will fade straight away.
This is all controlled by the 10AS module or in 2015my onwards the later Siemens unit with the newer alarm fob Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #678302 14th Jan 2018 8:58am
Cupboard
It's not beyond the realms of possibility that there are different reactions for different doors. The driver's door is treated differently to the other ones.
Post #678431 14th Jan 2018 8:01pm
Will17will17
Hi all Thanks for the replies, looks like a faulty switch now.
Today I unlocked both front doors and dis armed the alarm .
Opened the driver door and got in (light still on from disarm)
Light went out after approx 5 secs.
Keys not in ignition
Open drivers door - no interior light comes on (closed it)
Opened passenger door - light comes on (closed it and goes off gradually)
Going to clean the switch/ connections and see if this helps,
Thanks
Will
Post #679309 17th Jan 2018 6:07pm
Will17will17
Forgot to add I opened both doors while sat inside with ignition running and got the same results,
Will
Post #679311 17th Jan 2018 6:08pm
mk1collector
Check to see if the wire is still on the drivers door switch and if it's got a good earth. I had the same issue with my rear door. Ray
My build thread
Post #679350 17th Jan 2018 7:42pm
Will17will17
Switch is missing a bit of metal off the bottom - new one ordered, looks as though this is the issue.
Post #679424 17th Jan 2018 9:44pm
mk1collector
That will do it Thumbs Up at least it was a cheap fix. Ray
My build thread
Post #679488 17th Jan 2018 11:22pm
grafty99
Nice easy fix, ideal Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #679499 17th Jan 2018 11:32pm
