Home > Series Land Rovers > Oops - thought I had done with Series Landy's until..... |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10359 |
Love the paint
11th Nov 2017 8:08pm |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3461 |
Quick update
She has brakes... Small amount of welding to offside bulkhead pillar. Not sure how to finish this paintwise as rest of vehicle original.... She has rebuilt swivels and now steers Got engine running for 25 mins and even the rad holds water Freed off clutch and for the first time since 1981 is moved around under its own power! That was on Christmas Eve Ordered a new wiring loom as some/most/all of wires have rodent damage. Autosparks may be the biggest delay we have encountered so far sadly..... 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
31st Dec 2017 10:02am |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Nice!
31st Dec 2017 3:31pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Sounds good
Look forward to seeing some pics, you did the right thing with the Auto Sparks loom, Most brake downs are due to faulty wiring at that age! Expensive,but worth it 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
31st Dec 2017 5:19pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10491 |
Result 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
31st Dec 2017 10:31pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
not sure i would paint it! maybe put some matting inside to tidy up interior! My 109 thread
my youtube channel |
1st Jan 2018 1:20am |
Hi,
Not going to paint the whole thing, it's just what to do with the little areas of welding. More obvious on the bulkhead as you can see. Update : Welding done. Swivels and brakes rebuilt. Fuel tank refurbished and new SU pump fitted. Autosparks loom ordered but still 4 weeks left to wait until it arrives. Brake master cylinder away getting re sleeved. Tyres ordered, not going down the Avon route (sorry to the rivet counters but £200 a corner??!) popped the hood on to see how she looked Question, wiper motor looks period correct to me as a Lucas one? Going to remove and refurbish but some are saying looks nothing like an original? 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
13th Jan 2018 7:09am |
Hi,
Not going to paint the whole thing, it's just what to do with the little areas of welding. More obvious on the bulkhead as you can see. Update : Welding done. Swivels and brakes rebuilt. Fuel tank refurbished and new SU pump fitted. Autosparks loom ordered but still 4 weeks left to wait until it arrives. Brake master cylinder away getting re sleeved. Tyres ordered, not going down the Avon route (sorry to the rivet counters but £200 a corner??!) popped the hood on to see how she looked Question, wiper motor looks period correct to me as a Lucas one? Going to remove and refurbish but some are saying looks nothing like an original? Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
13th Jan 2018 7:10am |
you've been a busy boy My 109 thread
13th Jan 2018 10:04am |
Great progress
Painfully dear the Avon’s.... The wiper is nearly correct! They use the Lucas CWX usually, which yours is but has a different shaped body where the switch is. It’s probably from an MG or similar period classic. Perfectly acceptable though, although some will say not! Wipers were an option at that time, so people put anything on them. You will find every old Lucas part will have a date stamp, eg 4.54 being April 1954, This will be on fuse box, regulator, Dynamo, starter, wiper, etc Keep up the good work 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
13th Jan 2018 11:42am |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1613 |
Yes would agree with Ian on the wiper motor, I have seen quite a few on classic MG's. and as Ian says perfectly acceptable unless you are an ultra rivet counter
13th Jan 2018 3:07pm |
