Home > Alive Tuning > Defender 110 Lowered Springs
Page 6 of 6 <123456
Disco_Mikey
I'm back to work on the 5th. I'll measure then Thumbs Up
If you don't hear from me by midday, I have forgotten. Send me a PM to remind me Embarassed
Post #588375 29th Dec 2016 9:11am
John Fair
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
Thumbs Up
Post #588407 29th Dec 2016 1:26pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Springs now changed
As of 4.00pm yesterday I have had the standard Land rover 110 springs taken out and the Alive springs put in.
S.H.M.B.O. says she feels like it is the Disco 1 and a much better thing to drive. I have to agree with her it feels more planted on the road, corners better, and no more jarring of the back and neck. Also we can now get in and exit without having to use the side steps.
Front height with standard springs
Rear height with standard springs.
Front with Alive springs.
Rear with Alive springs.
Front wheel.
Rear wheel.
While having them fitted the headlights and fluid levels were checked. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #594506 19th Jan 2017 5:40pm
Dimitris_CY
2012 Defender 110 Puma 2.2 CSW Alaska White
I noticed that this discussion stopped more than a year ago. I wonder if the Lowering Springs For Defender 110 is still available - it's a bit confusing to see the kit listed on the Suspension Archive page on your website. Is it considered vintage in 2018 Very Happy ?
Also, this could be a naive question, but how do I know if my 2012 Defender 110, 2.2 has the genuine ARB already installed from the beginning. I'm traveling abroad now and will be able to check it only in 1 week. May be there is a rule of thumb to detect if an ARB was optional or mandatory in 2012. I'd rather order both the kit and the ARB (if needed) now so everything would be ready when I came back. Thanks, Dimitris
Post #677361 9th Jan 2018 11:40pm
JOW240725
Good morning Dimitris, welcome to defender2 Thumbs Up
The Alive 110 comfort lowering springs are still available on their website. I just think that maybe they don't suit everyone. They do lower the Defender and not sure if they are suitable if you tow heavy trailers or load up heavy, which is often the case with 110. I suspect it all depends on what you want them for. I've certainly not heard anything against them.
As for the ARB, I have a 2012 110 SW and so far as I know the ARB is fitted as standard on the station wagon, but not on all variants. Someone here will no doubt know but I believe the Utility and DCPU all have ARB as standard, but possibly not the hard top or pickups? The uprated ARB are generally 25mm diameter, but I'm not sure what the standard ARB is. I could measure tonight if you would like?
I'm not expert but hope this helps a little Thumbs Up James
MY2012 110 XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html
Post #677374 10th Jan 2018 8:39am
Dimitris_CY
Hi James, thanks a lot for your prompt reply. You are right - I've just seen both front and rear ARB fitted. I'll phone you thisMonday to discuss the lowering kit order.
Post #678002 12th Jan 2018 8:03pm
Page 6 of 6 <123456
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
