Home > In Car Electronics > Silly question - fuses and relays |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Really you only need one fuse per circuit, so that the relay and load are protected. Additional fuses introduce unnecessary potential for reliability problems 2002 90 Td5 Station Wagon
13th Dec 2017 8:28am |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 |
So in essence Assy -switch - relay would be overkill to have a fuse
13th Dec 2017 8:31am |
Not sure I understand what you're saying there. What do you mean by assy?
Any circuit needs a fuse, but only one fuse per circuit. Not a fuse each side of the relay 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Dec 2017 9:18am |
gotrcha
Accessories live -> Switch -> relay -> fuse -> load correct |
13th Dec 2017 9:41am |
It should be
Accessory live --> fuse --> switch --> relay --> load The fuse protects the whole circuit not just the load 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Dec 2017 11:04am |
Ok?
So the fuse only protects the switch circuit. The relay live to load is in itself another circuit albeit activated via a electro mechanical switch (relay) So in this case the fuse is only protecting the Low amp circuit? |
13th Dec 2017 11:14am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6460 |
You have two circuits, the circuit which controls the relay (switch for the relay coil). Normally the supply for this would be tapped from another circuit as it is very low current.
Then there is another circuit, the one switched by the relay. Generally you will take a new supply for this, and place a fuse before the relay. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
13th Dec 2017 11:36am |
GOT IT
13th Dec 2017 1:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19449 |
You will sometimes have for distribution boxes or Relay boxes etc have double fusing.
However, as Martin states all of that is correct. But you will often get, a master supply with larger cable i will use an example: 100A cable > fused at 80A with in a max of 20" from battery post ideally closer. Supplying a live bussbar or similar ditribution, down to either two loads say 40A fused each. > to any purpose required. Or to a Relay box for example with say 4x Relays with 20A capacity each with in-built standard fuses. Any issues with the circuit past the Relay the 20A fuse will blow, other circuits Remain live and active as well as the master supply. Any issues with the master supply cable run, the 80A master fuse will blow but all circuits will be down. I personally fuse in-line nearest supply source and use non fused Relays as they aren't always required. It varies by fit location, for most uses I don't use a fused Relay but in distribution blocks and boards they can be useful. Fusing is to protect the cable from fire, and not a device so the cable must be rated higher than the fuse rating. And both should be rated above the load, fuse should be below cable current capacity but around 5 - 10A above device current load. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
13th Dec 2017 3:32pm |
ok i get it
appreciated |
15th Dec 2017 2:42am |
