Home > Puma (Tdci) > Injector seal removal
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
Hi all
Removed all four injectors yesterday to get bench tested , two have failed so picked up a couple of reconditioned ones today.
I’ve purchased new copper seals and clamp bolts.
All was going well but I cannot shift the camshaft cover injector seals . Sounds daft but I’ve destroyed one in the process and was wondering if there’s a tip . Frankly they almost seem like they’re not supposed to come out. The rubber just comes off in chunks leaving the rest in place
Do I need to take the cam cover off to do it ? Looks fairly straight forward but don’t want to if not necessary!
I’m trying to get it all running sweetly before I apply my new BAS remap as it was smoking quite a bit and stunk of diesel .
Thanks in advance
Post #670732 13th Dec 2017 5:58pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Yes, they come out.
They age harden over time, which is why yours are breaking off.
You need this....
https://www.googleadservices.com/pagead/ac...amp;adurl= 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #670739 13th Dec 2017 6:23pm
Bluericky
Thanks ian
Are you saying that i need to remove the cam cover then to pop them out ?
I cant really see any other way without damging the cover or getting crud on the injector seats !
Post #670741 13th Dec 2017 6:30pm
ian series 1
Yes, I tend to take them off, it's easier in the long run,
Then at least you can give everything a good clean, and not have stray bits of hard rubber dropping where it's not welcome!
Also, if the seals have gone hard, the rocker gasket won't be too clever either,
So it's best to do it all at the same time.
Thumbs Up 80" 80" 86" 88" 90"
Post #670744 13th Dec 2017 6:51pm
zsd-puma
just lever them out with a screw driver, they'll break up and fall to bits, just fit new ones. Be careful to lever the seal and not the rocker cover.
Post #670764 13th Dec 2017 8:35pm
Bluericky
Thanks ZSD, I’m levering as much as i can but as you say im a bit worried about damaging the cover. I think I’ll whip off the cam cover as there’s a small amount of oil weeping around the gasket so may aswell change that as well .
Once the injectors are replaced will the fuel system need priming or can I get away with cranking it over ? Ill be swapping over the vcv on the pump aswell
Post #670774 13th Dec 2017 9:11pm
ian series 1
It'll start ok Thumbs Up 80" 80" 86" 88" 90"
Post #670778 13th Dec 2017 9:20pm
zsd-puma
if the cam cover gasket is leaking then yes it has to come off anyway. you can also flush out the crankcase vent on it with some diesel/parafin while it's off.
You should just be able to crank it over, as there will still be fuel as far as the fuel rail.
Post #670864 14th Dec 2017 9:21am
Roy5695
when swapping injectors and vcv i am sure you have to do a pump calibration and maybe even code the injectors... 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #670872 14th Dec 2017 11:29am
zsd-puma
Yes you need to recode the injectors if you're replacing them. Actually all you're doing is telling the ECU where each injector specific is.
Post #670915 14th Dec 2017 5:42pm
Bluericky
Thanks , got the cover off and popped out the 4 injector seals. It took all my weight leaning on a screwdriver to do it mind !
Cover is now back on with a new gasket and compound so shouldn’t be leaking for a while.
Now waiting on the new injector seals that I bought off eBay 5 days ago and still haven’t arrived, “fast and free” my a*se !
I now have the BAS2 diagnostic tool so will programme the injectors. Check all is working and then apply the remap , mildly excited about that
Post #671019 15th Dec 2017 10:29am
