Home > Td5 > td5 making tapping noise, stops when pedal lifted |
horus1970 Member Since: 27 Jul 2016 Location: north east Posts: 105 |
cheers will try that when my road defrosts ha,
12th Dec 2017 12:47pm |
injectors are self adjusting ?
14th Dec 2017 5:12pm |
yeah, self adjusting, never need to adjust for lash
14th Dec 2017 5:31pm |
if remove injectors to replace for seals and copper washer then injector slash adjust is needed
14th Dec 2017 5:41pm |
atakanmerdin Member Since: 15 Dec 2017 Location: Nairobi Posts: 26 |
I've got the exact same issue. And my harmonic damper is new sourced from turner engineering. Even tried with other "known" injectors no change. Oh and mine is also coupled with a rough idle and s little misfiring! Hot on the trail too... Let's hope!
15th Dec 2017 10:31pm |
yeah mine has started stuttering and taking a couple of turns in the morning to start, then its stuttery for a good while,
even when warm as soon as i dip clutch and brake it misses a beat? |
30th Dec 2017 6:22pm |
i have given up on td5, sold it and went back to my old 300tdi, been standing for 4 months and fired up after first heat and ticked over lovely,,, loved the look of my double cab but didnt love the ecu,,,
12th Jan 2018 5:19am |
bogwert Member Since: 03 Sep 2016 Location: Dundee Posts: 194 |
6th Feb 2018 10:21pm |
Had this issue and fixed!
1. Found ECU earth post wasn’t clean and fixed that. 2. Found two earth cables from main harness were wrongly mounted on the expansion tank mounting, connected them to engine block. 3. While there also cleaned the earth post on bulkhead behind the expansion tank. 4. Found copper washer on injector two was thinner and smaller in diameter - this fixed the rough idle. Please note when doing the injector copper washers you MUST clean the injector seats in the cylinder head, WURTH throttle cleaner plus made up tool (think tiny bottle brush). Also don’t force the washers onto the nozzle as they do deform. Rather use the action of installing them to apply even pressure. Engine is butter smooth again now. |
7th Feb 2018 6:03am |
