![]() | Home > Technical > Headlamp washer reservoir part number |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 ![]() ![]() ![]() |
PRC3300 I believe
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
ADU1784L is the timer relay and PRC5141 is the loom
This is from the list of numbers I gathered when looking to add factory headlight washers myself
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 ![]() |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16876 ![]() ![]() ![]() |
Fantastic, many thanks for the info!
Mind you I've just looked up the price and it is just under £100 for the washer bottle, and that doesn't even include the lid! ![]() No wonder it wasn't a popular option. |
![]() ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
I think the simple option is to mount the pump on the side of the standard reservoir, which has an advantage in that the headlamp pump will be a little higher than the screen pump, so the headlamps will run out first thus warning of low fluid.
There is so little space under the bonnet that I don't think a RRC or Disco2 res would fit (I have a spare D2 res), but thanks for the offer of a photo. |
Are you going to have them so they only work with the lights on? 2002 90 Td5 Station Wagon
I haven't yet decided how I will do it, but it will be one of the following:
1 ) Wire them so they squirt with the screen washers if the headlights are on. 2 ) Wire them so they are on their own squirter button but only squirt when the headlights are on. 3 ) Wire them so they are on their own squirter button but squirt whether or not the lights are on. 4 ) Combine 1 and 4 for the best of both worlds. I wasn't planning to bother with a timer relay, at least not initially. I suspect that they'll empty the reservoir fairly quickly. |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 985 ![]() ![]() ![]() |
For £100 plus other bits and fitting, you could just lean out of the window at traffic lights and pay pedestrians to wipe the headlights!
Isn't that what the Squeegee gangsters are there for?
