Home > Technical > Headlamp washer reservoir part number |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
PRC3300 I believe 2002 90 Td5 Station Wagon
7th Dec 2017 6:19pm |
ADU1784L is the timer relay and PRC5141 is the loom 2002 90 Td5 Station Wagon
7th Dec 2017 6:21pm |
This is from the list of numbers I gathered when looking to add factory headlight washers myself 2002 90 Td5 Station Wagon
7th Dec 2017 6:37pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
7th Dec 2017 8:31pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16865 |
Fantastic, many thanks for the info!
Mind you I've just looked up the price and it is just under £100 for the washer bottle, and that doesn't even include the lid! No wonder it wasn't a popular option. |
7th Dec 2017 11:13pm |
there must be other options. I could take a pic of one from the range rover if you like? Also has level sensor 2002 90 Td5 Station Wagon
7th Dec 2017 11:29pm |
I think the simple option is to mount the pump on the side of the standard reservoir, which has an advantage in that the headlamp pump will be a little higher than the screen pump, so the headlamps will run out first thus warning of low fluid.
There is so little space under the bonnet that I don't think a RRC or Disco2 res would fit (I have a spare D2 res), but thanks for the offer of a photo. |
8th Dec 2017 12:25am |
Are you going to have them so they only work with the lights on? 2002 90 Td5 Station Wagon
8th Dec 2017 12:36am |
I haven't yet decided how I will do it, but it will be one of the following:
1 ) Wire them so they squirt with the screen washers if the headlights are on. 2 ) Wire them so they are on their own squirter button but only squirt when the headlights are on. 3 ) Wire them so they are on their own squirter button but squirt whether or not the lights are on. 4 ) Combine 1 and 4 for the best of both worlds. I wasn't planning to bother with a timer relay, at least not initially. I suspect that they'll empty the reservoir fairly quickly. |
8th Dec 2017 1:30am |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 985 |
For £100 plus other bits and fitting, you could just lean out of the window at traffic lights and pay pedestrians to wipe the headlights!
8th Dec 2017 8:29am |
Isn't that what the Squeegee gangsters are there for?
8th Dec 2017 9:25am |
