Home > In Car Electronics > Weatherproof 12v Plugs and Sockets
rockster57
I’m wanting to build a roof rack wiring loom to feed 12v power to driving lights and various camping lights and power points on the rack itself. I’m looking for help finding a source of some weatherproof plugs and sockets for the project. My idea is to have a type of fixed bulkhead type socket mounted on the rear vertical surface of the roof above the gutter. When the roof rack is mounted it’s loom will simply plug into the socket/s and the reverse when I need to remove the rack. Any pointers please?
Post #669482 7th Dec 2017 8:46am
rallysteve
United Kingdom 1984 Defender 90 V8 Petrol PU Caledonian Blue
ITT Cannon Trident connectors. Not cheap though!
Steve 02' 110 TD5 Double Cab
84' 90 3.9 V8 Caged Pickup
Post #669483 7th Dec 2017 8:50am
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
I’m looking for something similar, I took the cable out, via a marine cable gland in the rear panel, for my solar panel and used an amp seal connector to the panel. However I think these are a bit insubstantial and a pig to wire so I too am looking for a quality, in line connector.
For your application, suggest you look at DriPlug marine connectors, there are quite a few different types, up to 8 way, and a decent current rating as well.
http://www.ecs-marine-equipment.co.uk/mari...23520.html
Chris 2010 Defender 110 Station Wagon, Santorini Black.
Post #669497 7th Dec 2017 10:25am
dorsetsmith
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
or http://www.mobilecentre.co.uk/index.php?ma...cts_id=701 pickup 90 TD5 2006
HT 90 TD5 2003
Post #669513 7th Dec 2017 11:43am
smb
Try https://www.12voltplanet.co.uk and if you type in the code "nldec17" you may get a 10% discount
Post #669532 7th Dec 2017 1:50pm
miker
I'd probably use XLR4 or (Mis)use a powercon or speakon connector from neutrik.
Post #669536 7th Dec 2017 2:02pm
rockster57
That’s a great response. I’ll check out all those suggestions when I get home from work. Thank you everyone. Thumbs Up
Post #669545 7th Dec 2017 2:32pm
PaulMc
The Bulgin Buccaneer range of connectors are my recommendation, see my post here -
http://www.defender2.net/forum/post449301.html#449301 Paul.
Post #669729 8th Dec 2017 2:23pm
And mine! Good value too.
Post #669739 8th Dec 2017 3:48pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
