Home > In Car Electronics > Weatherproof 12v Plugs and Sockets |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2196 |
ITT Cannon Trident connectors. Not cheap though!
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
7th Dec 2017 8:50am |
ChrisCM Member Since: 10 Jun 2013 Location: Cornwall uk Posts: 572 |
I’m looking for something similar, I took the cable out, via a marine cable gland in the rear panel, for my solar panel and used an amp seal connector to the panel. However I think these are a bit insubstantial and a pig to wire so I too am looking for a quality, in line connector.
For your application, suggest you look at DriPlug marine connectors, there are quite a few different types, up to 8 way, and a decent current rating as well. http://www.ecs-marine-equipment.co.uk/mari...23520.html Chris 2010 Defender 110 Station Wagon, Santorini Black. |
7th Dec 2017 10:25am |
7th Dec 2017 11:43am |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Try https://www.12voltplanet.co.uk and if you type in the code "nldec17" you may get a 10% discount
7th Dec 2017 1:50pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1758 |
I'd probably use XLR4 or (Mis)use a powercon or speakon connector from neutrik.
7th Dec 2017 2:02pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
That’s a great response. I’ll check out all those suggestions when I get home from work. Thank you everyone.
7th Dec 2017 2:32pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 486 |
The Bulgin Buccaneer range of connectors are my recommendation, see my post here -
http://www.defender2.net/forum/post449301.html#449301 Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
8th Dec 2017 2:23pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16858 |
And mine! Good value too.
8th Dec 2017 3:48pm |
