Home > Puma (Tdci) > Turbo temp fault |
pkrynicki1984 Member Since: 06 Dec 2017 Location: stoke on trent Posts: 8 |
Have seen similar threads.
When cruising on a run my turbo seems to stop boosting altogether. seems to turn into a gutless old diesel , resetting the ignition cures it but it happens soon after. Engine management light is on. 2007 2.4 tdci |
6th Dec 2017 10:15am |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
have you checked the air pipes for splits its a common fault
6th Dec 2017 1:16pm |
will do thanks.
seems strange that a reset sorts it out. |
6th Dec 2017 2:40pm |
Sound more like electric problem with turbo controls ( Actuator vane) VGT if you can reset by switching ignition off
and no high pitch air sound and lots of black smoke from exhaust plug the diagnostic in and read fault codes loge in ECM this will help you track down you problem work shop Manuel below for 2.4 engine https://1drv.ms/b/s!AtZSoWFHDgnGhQoLf-ZCjkI5M0R7 |
6th Dec 2017 3:16pm |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 |
See my thread on temporary turbo failure.
I thought initially that my problem was a heat problem but I had no change in temp & no warning lights. In your case I would remove the MAF sensor & wash it off - plenty of info on this site & see if that clears the problem. Meanwhile I will be investigating my problem Guy May your life be like toilet paper ; long & useful. |
6th Dec 2017 11:42pm |
Thanks for that.
7th Dec 2017 9:14am |
Many thanks for that.
I'll give it an inspection later , would it still make sense a ignition reset cures my problem ? usually for a very similar amount of time until the turbo dies again? |
7th Dec 2017 11:36am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16875 |
It is possible, if, for example, something is intermittently grounding and causing a fault, then un-grounding.
7th Dec 2017 1:31pm |
