Home > 4x4 Overlander > Nakatanenga ANR Classic Steel Deep-Dish Rims
Page 3 of 6 <123456>
datcullen
2015 Defender 110 Puma 2.2 USW Java Black
Me too depending on final price. 110 UW - '15 2.2
90 - '85 V8 soft-top
RRC - '84 5 door, Option Pack C, 33k miles from new
Elise S1 - '00 Millennium SE
Elan +2 - '68 kit built by my dad
Panda 4x4 - '87 in Italy
Post #664989 17th Nov 2017 7:56am
L110CDL
England 1996 Defender 110 300 Tdi PU Coniston Green
I'm very interested in these, but i'm not sure if they would look right on Millie ? i do like the " old skool " look though Wink 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #668123 30th Nov 2017 11:58pm
grafty99
I think they'd look spot on Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Defender Thread http://www.defender2.net/forum/topic50767.html
Post #668125 1st Dec 2017 12:01am
Sulisuli
Clayton you need a set of Bowlers Whistle ..not these for Millie Very Happy Being a sewage diver at least I know how deep the 💩 will be at work today.
2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #668142 1st Dec 2017 6:22am
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Nooo he needs a set of these ANRs Razz 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #668353 2nd Dec 2017 1:41am
L110CDL
Rolling with laughter i have always liked the bowlers and would of got them if they had been right for Millie but they dont and these do look right for her Whistle Very Happy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton.
Post #668796 3rd Dec 2017 11:03pm
Sulisuli
Thumbs Up Being a sewage diver at least I know how deep the 💩 will be at work today.
2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #668797 3rd Dec 2017 11:05pm
Mr Fox
United Kingdom 1983 Defender 90 V8 Petrol ST Bronze Green
(Disclaimer - very non-technical question ahead, possibly a very thick question Wink )
Setting aside construction methods and/or materials, is the benefit of these over something like the HD Wolf Wheels the fact that they are deep dish and therefore the standard OEM five bolts more than adequate to secure them? Or is it that the deep dish allows for the fitment of a wider tyre?
I can see the style difference but I’d like to understand what benefit these have over standard steel wheels.
Post #668806 4th Dec 2017 12:12am
Kit
I think this is more form over function but from a functional point of view they allow you to run a big tyre and keep a good turning circle without using spacers. The stud thread aspect isn't a big factor that's likely to impact anyone.
I'm going to run 285 75 16 on mine: http://www.defender2.net/forum/topic58001.html
Thumbs Up 1993 200 Tdi 90 CSW
Post #668807 4th Dec 2017 12:29am
L90Andy
United Kingdom 1984 Defender 90 Other ST Arles Blue
Mr Fox, the main advantage of this wheel over a standard steel is the ability to safely fit wider tyres.
Standard steel rims are 6" wide and should only be fitted with tyres around 235 section. Wolf steels are 6.5" wide and can take anything upto 255 section. These I believe are 8" wide so a much larger range of tyres can be fitted, as mentioned including 285's.
The other advantage is the offset, which pushes the whole assembly away from the hub therefore will improve turning circle even with the wider tyres fitted. This also prevents the need for spacers.
They do all this while appearing as standard wheels, which has not been possible before now.
Thumbs Up My Defender: http://www.defender2.net/forum/topic39625.html - SOLD!
My current Ninety: http://www.defender2.net/forum/topic56071.html
Post #668817 4th Dec 2017 7:43am
Mr Fox
Cheers Andy (and Kit), I assumed this was the case but wanted to check.
Post #668832 4th Dec 2017 9:53am
leeds
Site Sponsor
Some technical data on the rims. (Slightly edited)
The ANR Classic 8X16 ET0 is made exclusively for Nakatanenga.
Data sheet:
Wheel size: 8X16
ET: 0
Max Load: 1160 kg
circle: 165.1 mm
Center hole: 113 mm
Centering: Bolt centering
Suitable for almost all defenders;
Approved for the following tire sizes:
245/70 R 16
255/65 R 16
255/70 R 16
255/85 R 16
265/70 R 16
265/75 R 16
275/70 R 16
285/75 R 16
295/75 R 16
Must admit I have to stop and think about the effect of ET, offset, backspacing.
Brendan http://www.4x4overlander.com
Brendan's phone numbers 07929 604668/01422 243966 up to about 9pm
email address brendan@4x4overlander.com
Post #668844 4th Dec 2017 10:22am
Steve R
2013 Defender 110 Puma 2.2 USW Keswick Green
I’ve just been informed (thanks UtilityTruck Thumbs Up ) that a separate thread has now been set up in the Group Buys section, so for those of us that missed it:
Post #669591 7th Dec 2017 7:45pm
doncarloz
Austria 2015 Defender 110 Puma 2.2 DCPU Stornoway Grey
Is there an update regarding the availability of those rims yet?
Post #684305 5th Feb 2018 4:47pm
Still waitiing whilst TUV certificates are legal and passed :-/ @v8_scumbag
Post #684318 5th Feb 2018 6:08pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
