Home > Puma (Tdci) > No Glow Plug Supply Voltage |
What does the DTC for the glow plug circuit actually say?
5th Nov 2017 3:02pm |
Click image to enlarge Click image to enlarge Last edited by dorsetsmith on 5th Nov 2017 7:31pm. Edited 1 time in total |
5th Nov 2017 7:27pm |
swifty Member Since: 05 Nov 2017 Location: here Posts: 7 |
Two DTC showing
P037D-29 Glow plug relay sense circuit, status PERMANENT P1103-00 Mass air flow sensor in range but higher than expected. Reset DTC and this one gone for now. Thanks for the wiring diagram, its the same one i have. Forgot to mention in the first thread four new Bosch glow plugs fitted. |
5th Nov 2017 7:28pm |
Been thinking about this problem one possibility is the ground from the ECM to the glow plug relay is not been switched on. I believe the ECM needs the CHT sensor to say the temperature is below a certain degree set point for the ground to be switched on. Is there a document on the net that has the expected resistance readings for the sensors for the puma.
Many years ago I had a manual for fault finding on what was at that time the up to date fuel injection systems, it went into great detail on fault finding with sensor values as per ambient temperature etc so a reference book like this on the puma would be very helpful. |
6th Nov 2017 8:36am |
Glow plug relay sense circuit see below
Click image to enlarge (Glow plug relay sense circuit, status PERMANENT) check wiring for shorts if your DTC showing P037D-29 Glow plug relay sense circuit, status PERMANENT but not supply to glow plugs |
6th Nov 2017 11:14am |
If anybody requires the CHT resistance values are as follows
Coolant Temperature Sensor Response Temperature (Degrees Celsius) Resistance (Kohms) Voltage (Volts) -40 925 4.54 -30 496 4.46 -20 277 4.34 -10 160 4.15 0 96 3.88 10 59 3.52 20 37 3.09 30 24 2.62 40 16 2.15 50 11 1.72 60 7.5 1.34 70 5.6 1.04 80 3.8 0.79 90 2.9 0.64 100 2.08 0.49 110 1.56 0.38 120 1.19 0.29 130 0.918 0.22 140 0.673 0.17 150 0.563 0.14 |
7th Nov 2017 11:13am |
Problem sorted, not really sure what it was removed the centre plug on the ecm to check continuity of the green/blue wire C1 from the glow plug relay coil circuit which was ok, replaced plug then pulled fuse 39 which had slight corrosion cleaned and checked for voltage at the glow plug post had 10.8v so all fixed.
The permanent glow plug DTC is still logged and won't clear, I've read the permanent DTC won't clear until 3 clear engine cycles have been completed is this correct? |
11th Nov 2017 8:34pm |
Sounds about right. Start the car, run it for a minute or two and switch off again 3 or 4 times. |
12th Nov 2017 11:51am |
Re posting this problem as it come back again.
Checked the following points first, all four glow plugs working which they should be as there new. No volts at the glow plug post which is on top of engine right hand side. DTC P037D-29 Glow plug relay sense circuit, status PERMANENT Removed the ECM from bulk head to check relay circuit between glow plug relay and ECM- circuit ok.This circuit is the ground for the relay coil and is switched on by the ECM conditions being correct which they were it was 1 degree and the cylinder head/block read 4.5 degrees with a temp ir meter. I did check the supply volts to the glow plug relay both the coil and load supply which both are ok. Then moved my attention to the CHT at 4.5 degrees. Supply volts 4.95v, resistance 82 omhs and 3.95v on the return circuit which falls about right with the information listed in the workshop manual for the temperature at the time. As a temporary fix I've wired a push button switch to earth the glow plug relay coil basically doing what the ECM does when the condition are correct for the glow plugs to be used in a cold start situation, chose a push button to prevent the glow plugs being switched on by mistake also wired a digital volts display into the glow plug supply circuit so that I can easily monitor the circuit. Any body experienced a similar problem. I am now thinking that there may be a problem with the ECM or any suggestions guys. |
19th Nov 2017 6:57pm |
This morning went out to start the the landy in 4 degree temp and there was 10.8v at the glow plugs which is strange as when I left it yesterday there was no voltage at the glow plugs, engine started and drove for a good twenty minutes during which time the glow plug supply stayed on this I knew from the voltage gauge wired in yesterday. Engine up to temperature, switched the engine off the glow plug supply stayed on for about five seconds then the relay dropped out.
Switched the ignition back on and no supply to the glow plugs,so it looks like the circuit fault is that the glow plug supply is staying on causing the ECM to disconnect the glow plug relay coil earth the next time the ign switch is turned on. In my reckoning there's possibly a fault with the CHT, if id had my meter I could of checked the CHT output resistance and voltage along with the ir temp gauge to see if the fault was with the CHT. Can the ECM disconnect a faulty circuit and log it as so then if the ECM is disconnected from the vehicle then reconnected the fault is reset. The reason I ask this is that all that I done yesterday apart from check wiring etc was disconnect the ECM harness. |
20th Nov 2017 8:35am |
20th Nov 2017 10:14am |
Willie123 Member Since: 26 Nov 2023 Location: Cheshire Posts: 3 |
First post here so apologies if I miss any group rules.
I've got a 2009 2.4tdci and I seem to be having a similar issue to yourself. I'll attach the codes below. I've changed the maf sensor to no avail, I've also bought a new maf sensor plug, as there's a few bare conductors leading into the OEM plug so not sure if they're shorting and getting a high voltage over them. I've also bought a new glow plug relay and new glow plugs themselves. I checked what voltage I'm getting at the plugs and it was only 8 V, so I'm not sure if that's indicative of an issue with the wiring to the plugs themselves. In my opinion the glow plugs don't seem to be working at all, it's relatively cold at the moment and there seems to be a hell of a lot of white smoke on start up. I also broke down on the m61 the other day and got trailered home and then it was completely fine. Did you manage to get your issues fixed? P037D-29 (GLOW PLUG RELAY SENSE CIRCUIT - SIGNAL INVALID) P1103-00 (MASS AIR FLOW SENSOR IN RANGE BUT HIGHER THAN EXPECTED - NO SUBTYPE INFORMATION) P0380-11 (GLOW PLUG/HEATER CIRCUIT A - CIRCUIT SHORT TO GROUND) Best wishes Will |
26th Nov 2023 5:31pm |
