Home > In Car Electronics > USB Socket Search
Page 2 of 3 <123>
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
Been doing some experimenting and came up with this: -
Post #649914 12th Sep 2017 7:22pm
ibexman
Well done that man
Post #649919 12th Sep 2017 7:42pm
greenlandrover
Finally got around to installing the USB charger
Still need to install one on the passenger side too.
Post #662412 7th Nov 2017 3:23pm
rockster57
United Kingdom 2011 Defender 110 Puma 2.4 CSW Zermatt Silver
That’s ace!
Can you explain what you did to make the socket?
Is this what you started with......
Post #662429 7th Nov 2017 4:50pm
Martin
Site Admin
greenlandrover wrote:
Nice find!
Done a quick search and those part numbers don't seem to be available in UK.
Did you try the small 8 digit part numbers (00414040 / 003323033) visible below the engineering number?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #662432 7th Nov 2017 4:59pm
greenlandrover
Cheers Thumbs Up
Yes I started with one of those sockets.
Basically took off the spring lid and opened it up by hand using a step cutter bit until it fitted the Blue Sea USB charger.
Then removed the existing cigar lighter and filed hole, again to suit the USB charger.
Removed contacts from existing plug (i.e. cut plastic housing off) and put some heat shrink over them to prevent shorts.
I think the positive is purple/brown. Ground is black. Mine is an 07MY so it may be different on yours.
I put an ‘O’ ring either side of the panel. On the front it fills up the recess in the panel. The one on the back acts as a sort of spring washer.
Let me know if you need any ‘O’ rings. I’ve got a box full and I’ll never use all of them!!! Laughing
Cheers,
Jason
Post #662434 7th Nov 2017 5:03pm
greenlandrover
Martin,
I got them from a site in Germany I think.
I’ll have a look when I get home and pm you a link
Cheers,
Jason
Post #662435 7th Nov 2017 5:04pm
rockster57
[url]http://www.baas-parts.de/produkte/steckdosensysteme/za22-Zigarettensteckdose/#prettyPhoto
If that’s the one, there’s a uk source of the same part:-
[/url]http://www.conrad-electronic.co.uk/ce/en/product/1289381?insert=EG&awc=5769_1510082526_979e87dfebc0ee817807fb01dee97fad&utm_source=affiliate_aw&utm_medium=global_aw&utm_campaign=global&utm_banner=global&WT.mc=affiliate_aw_global
Post #662481 7th Nov 2017 8:28pm
rockster57
Just found this...
http://www.conrad-electronic.co.uk/ce/en/p...K?ref=list
Post #662484 7th Nov 2017 8:50pm
greenlandrover
That’s nice!
Another thing I’ve thought about for the passenger side is hiding the charger itself behind the dash and then run a USB cable to one of these: -
http://www.neutrik.com/en/multimedia/usb/nausb-w-b
With one of these to keep the dust out: -
http://www.neutrik.com/en/multimedia/multi...ies/sccd-w
Post #662591 8th Nov 2017 11:11am
nihwrd
USB Connector (not Charger)
Hi all
I've recently upgraded to a Double Din fascia and didn't remove the cigar lighter from the old one as I thought I'd replace it with a USB connector instead.
My H/U has 2 USB inputs (one for ApplePlay) but the second supports iPod or other device, so I'm after a USB connector rather than a charger. Any views on what is the best option (to fit in the existing lighter hole)?
Nick
Post #698469 4th Apr 2018 12:26pm
greenlandrover
My post above yours is just a connector so you could use that Thumbs Up
Post #698478 4th Apr 2018 12:54pm
nihwrd
Hi GL
I note that the one in your post has a square end - is this removable or does it sit inside the fascia?
Nick
Post #698518 4th Apr 2018 3:30pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
The rectangular surround of the Neutrik connectors can sit on either side of the mounting panel. http://www.neutrik.com/en/multimedia/multimedia-connectors/usb/ Full engineering drawings are available on each product page.
Post #698522 4th Apr 2018 3:47pm
nihwrd
All
Just ordered one of these:
https://www.amazon.co.uk/XTRONS%C2%AE-Dash...B00VWO746G as my H/U has both Aux and USB in.
Will fit it this weekend and report back
Nick
Post #698546 4th Apr 2018 5:04pm
Page 2 of 3 <123>
