Home > My Defender > My 110 MILLIE. |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
my workshop was much the same over the weekend 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
22nd Oct 2017 8:00pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10420 |
Better out than in 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
22nd Oct 2017 8:07pm |
22nd Oct 2017 8:10pm |
On Wednesday millie went in for another 6000 mile service but this time she was going in for 2 days instead of 1, this was because i wanted some other stuff done at the same time sorry no pic's, one of the " extra's " was to fit new genuine front disc's, calipers and pads as the front started to not wear right ( not genuine ones ) and the O/S/F caliper was not right so now i will have to bed them in for a little while she is going great at the moment and well glued to the road i have even a bigger grin at the moment when driving 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
28th Oct 2017 8:52pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 4908 |
I still want my brakes doing Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
1st Nov 2017 8:30pm |
I take it Procta that you will be doing them ? if so, that day will come as long as you have got all the bits ready 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
1st Nov 2017 9:23pm |
So after a good 5 week bedding in period for the brakes there was something not right with them as, if you wanted to do an emergency stop, i'm not sure that you could so millie went in yesterday to find out whats going on, so when i went to pick her up, the mechanic told me that the vacuum pipe had a hair line crack in it, so a temporary fix was done ( all done properly with good pipe ) until they get one in stock as they did not have one and then just to make sure they changed the disc pads for some EBC greenstuff ones and then tested the brakes on there mot set up and so after a short time using millie, the brakes are so much better and with a bit more bedding in i will able to do a emergency stop without worrying if i can or not
At the same time i had this put back on with a brand new one....................................... Click image to enlarge The reason for taking it off in the first place was that she was ok until the first viscous went and from then on they would last just over a year, so after the third or fourth one went i put the kenlow fan on. Earlier this year i started having problems with it and it finally packed up on the wales trip, so i bodged it so one fan would work when i connected the wires when she needed to be cooled down, so now i'm back to the old skool way Other than the above she going a treat 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
16th Dec 2017 9:55pm |
great to hear that your brakes are sorted, yellow stuff is what I run the 306 and they are good mind.
I didn't know that the viscous fans can fail! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
16th Dec 2017 11:57pm |
Nor did i until they did after a year i must have had a run of bad luck with them 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
17th Dec 2017 8:42pm |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1829 |
hey mate, I found the box for the ipad thing. I took a photo, but I can't post it from this device.
Anyway, it's a Dension Ice Link One - I had a quick google and it seems to be discontinued, though there might be some used ones on ebay? I also tried googling ipod FM cradle, and got some stuff that's close.... I guess I must have bought and fitted this back in 2008, or possibly even earlier... so the way electronics go these days it has to be really obsolete.... Sorry! |
17th Dec 2017 11:06pm |
Ok Donald, many thanks for having a look i also tried on ebay and found some for sale, but they had a make of car that it was for, did your one have that or was it a universal one ? many thanks again
Would this one be the same ..............................https://www.ebay.co.uk/itm/DENSION-ICE-LINK-FM-HW-V1-03b-IPOD-INTERFACE-ADAPTOR-NISSAN-VW-FORD-VAUXHALL/272983970131?hash=item3f8f1cd153:g:nuEAAOSwAHBaM8lT 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
18th Dec 2017 9:03pm |
Hi Clayton,
Definitely a 'generic' item - any car. The one you linked to would be fine but it was obviously missing the screw-in attachment to hold the cradle. They came with air vent clips too. Mine's still in the packet/box because it didn't work in the Landy. There's no moving parts, so I can't see any problem with getting a good, used one. Maybe the plug might be a bit worn if it was used a lot. Depends how someone used it. I went for a dedicated car ipod, so it stays permanently attached. Obvioulsy ipod are old tech now - surprising that such a thing would become obsolete so quickly. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
19th Dec 2017 8:23am |
shayes Member Since: 29 May 2016 Location: Devon Posts: 153 |
Morning,
I think I saw your lovely Rover in Holsworthy, Devon. This would have been last week or the week before at either 0700hrs ish or 0900hrs ish. Dropping my daughter off for the bus to Exeter. At the time Millie was loaded with thatching and looking good. Kind regards, Simon |
19th Dec 2017 8:46am |
Hi Simon, yes that would of been about 9.00 ish going through Holsworthy as im working near Bude at the moment, will keep a look out for you in the future 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
20th Dec 2017 8:58pm |
