Home > General > The height thread
Van Whalen
Australia
The height thread
Hi All,
I'm hoping someone can do me a favour - measure the height of your defender 90, 235/85r16's and stock suspension from ground to its highest point. I know the 'offical' documents say anything from 2000 to 2187?.
Maybe we can make this thread a resource for the common question of 'how high', 'will it fit' etc etc.
So, get your measuring sticks out.
Template -
- make
- year
- tyres
- lift
- measurement to highest point (roof at back door?)
- roof rack if any
- measurement to highest point on rack
Post #656493 11th Oct 2017 9:33am
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
I did this just before my 90 arrived last year. It's totally standard and on MTR tyres. Measures a fraction
under 2 metre's at the high point which is the back of the vehicle.
My garage door is 2.07m high, so no problem !
Post #656527 11th Oct 2017 11:47am
MartinK
Not a 90, but my 110 is 80 inches high...
that's 2 metres and 3cm in new money Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Volvo XC70 (Work)
BMW K1200RS
Post #656531 11th Oct 2017 12:12pm
Sockpuppet
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
As above unmodified 110 USW is 2.05m so about 80 1/2 inches.
Post #656536 11th Oct 2017 12:37pm
Mean Green
1993 200tdi 90 265/75/16 BFG's + roof rack (Discovery 2 rack modified to fit 90, so stands a little taller). Stands 7ft 2inches or just a shade under 2.2 metres.
Post #656566 11th Oct 2017 3:39pm
geobloke
Just under two storeys high for my 110... Shocked
Post #656575 11th Oct 2017 4:20pm
Geo
Scotland 2015 Defender 90 Puma 2.2 XS CSW Indus Silver
2015 Defender 90xs Station Wagon, 78 inches to highest point.
Post #656587 11th Oct 2017 4:48pm
Avion8
Australia 2015 Defender 90 Puma 2.2 Heritage Edition SW Grasmere Green
I did this exercise recently as we bought a new property that neither of my Defenders fit in the garage, so had to build a separate shed!
2015 Defender 90 Heritage is 1980 mm's to highest point.
2000 Defender 110 TD5 is 2060mm's to same point, which is roof at the back above the rear door.
Both on standard Continental AT's. 1955 Series 1 107" Pick up.
1977 RRC Suffix 'D'.
2000 Defender 110 TD5 Xtreme.
2015 Defender Heritage 90.
Post #656750 12th Oct 2017 12:20pm
Laurie
My Ninety clears 2.1 mtr carpark barriers but not 2 mtr ones.
Post #656753 12th Oct 2017 12:28pm
zsd-puma
Bear in mind the height will depend on whether the car had HD suspension fitted as an option when it was new. HD springs make them sit higher.
It also depends on the spec, a USW sits higher at the back as it doesn't have the weight of the seats in there to compress the springs.
The heights in the Handbook says something like "With all accessories fitted" - which means a roof rack and i would assume standard suspension.
Post #656823 12th Oct 2017 5:27pm
L110CDL
My 110 height is 78 inches to the top of my roll cage and is on 265/75/16 BFG AT KO2 and is on the same suspension when it came out of the factory, mine is a pick up Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
1988 Land Rover 90 Blue (project )
McCormick International B414 Tractor.
Clayton.
Post #656921 12th Oct 2017 10:02pm
charcoal
1998 Defender 110 300 Tdi SW Baltic Blue
My 110 is about 230cm which has stock suspension, 750R16C and brownchurch roof rack Thumbs Up 1998 Land Rover Defender 110 County Station Wagon Cool
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #656948 13th Oct 2017 1:52am
Van Whalen
Australia
Thanks to all who have replied so far!
If you haven't included tyre size/lift/etc in your post, would you be so kind to update your post?
My Defender 90 is as follows -
- MY11 Defender 90 Limited Edition (Australia)
- rear seats
- 235/85/R16 on Sawtooth Alloys
- Standard factory springs
- No roof rack
- Highest Point = Xmm @ rear edge of roof? (will measure once it arrives, its on a truck from Perth to Melbourne)
Also worth noting, how high are the ribs on the roof? 5mm?
Very Happy Thumbs Up
Post #656949 13th Oct 2017 1:55am
Profyaffle
United Kingdom 1993 Defender 90 200 Tdi HT Arles Blue
Mine is:
MY 1993 Defender 90
235/85 16
Urban Lowering springs
No roof rack
Height = 1.99m 78" 1993 200Tdi Defender 90
Post #656986 13th Oct 2017 9:29am
Hal
2011 MY Defender 110 XS Station Wagon
Continental Cross Contact 235/85 R16 on std Alloy Boost and std springs, no roof rack, no RAI
2030mm highest point rear of roof
I won't go in multi-story car parks with height less than an indicated 2080mm (small speed bumps in floor can cause bounce!)
NOTE: Radio aerial is a reasonable tell-tale being 2050mm fully extended - do you really believe the signs in car parks?
(long term plan, as wife allows: safety devices full roll cage [better than a roof rack?], Raised Air Intake SN4 [may not fit with roll cage?], remove XS carpet as water gets in!)
Post #657029 13th Oct 2017 12:31pm
Site Copyright © 2006-2017 Futuranet Ltd & Martin Lewis
