Home > Wheels & Tyres > tyre sizes for Boost alloys |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7664 |
so, will 285s fit width wise on a boost rim? Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
4th Dec 2015 7:22pm |
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 |
Seeing as you asked, No they wont, not if you comply with the manufacturers stated rim size.
Of course if you want to ignore that and any legal/insurance issues that may crop up if you do have a bad day, then, as many people will tell you, they have them fitted and never had any problems..... etc etc. Your call. 3 Landrovers |
4th Dec 2015 7:54pm |
thank you Cheers
6th Dec 2015 7:25pm |
what width is a LR Boost alloy please? plus a SVX style dual tone? Cheers
12th Oct 2017 12:14pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16812 |
Boosts (and Deep Dish) alloys are 7" wide, 33mm offset.
Sawtooths are 7" wide, 20mm offset. I don't have data for the SVX dual tone, I am afraid. You can run 285/75 x 16 BFG tyres on Boosts with no problems, however (1) the rims are narrower than tyre manufacturer's minimum recommended minimum, which could conceivably cause an issue in the event of bad things happening (although I have never heard of an authenticated case of there being issues - it seems to be another of the many Internet legends), and (2) 285s on Boosts do have a detrimental effect on turning circle. This can of course be mitigated with 30mm spacers, but then you will get crud up the side of the vehicle in huge doses, and also fall foul of the "spacer police" who will tell you that they're dangerous and your soul will burn for eternity for fitting them. Once again, however, they are quite safe if used and fitted properly. Clearly you should tell your insurance company, etc., etc., it is a great shame that BFG seemingly have no intention of making the AT KO2 in 255/85x16, since it is the ideal size for a Defender and I am sure would be a good seller. I don't know why they make the KM2 in this size and not the KO2. Last edited by blackwolf on 12th Oct 2017 12:57pm. Edited 1 time in total |
12th Oct 2017 12:55pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4350 |
Hi JST. the standard Boost wheel is a 16" x 7" with a 33mm offset.
I have just fitted 285/75/16 BFG AT KO2s on these and they fit just fine. Many many folks running this size tyre on Boost wheels. 235/85/16 Vs. 285/75/16 Click image to enlarge Full 285 setup Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
Hall46 Member Since: 30 Dec 2017 Location: Ayrshire Posts: 42 |
That looks perfect any spacers??
26th Feb 2018 10:12pm |
