Home > Tdi > High Mileage - Should I worry |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1967 |
No. Just enjoy it!
21st Sep 2017 11:32am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7873 |
I'm no expert but my opinion would be that I'm sure the mileage was reflected in the price you paid for it so just keep it well maintained and if anything breaks it can be relatively easily replaced. Enjoy it and post photos when you can! James
21st Sep 2017 11:56am |
zaz9 Member Since: 21 Sep 2017 Location: KL Posts: 31 |
Thanks for the reassurance James and for the warm welcome too. Going to get a fresh coat of paint and some upgrades here and there. Will post photos soon! Also your 110 is a beauty
21st Sep 2017 12:31pm |
Please be aware I talk from what I've read with no real expertise!! I'm sure others will give you better advice!
Thank you for the compliment, our 110 is my pride and joy and mid-life crisis. Be warned this site could cost you a fortune with ideas and upgrades!! But that's the fun of Defender! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
21st Sep 2017 12:45pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 640 |
I always like to consider it as percentage factor to make me feel better doing a journey in a high mileage car.
Say you are doing a 600mile trip. A high miler will hardly notice the difference in miles while the low miler it will see a significant % increase. Which would you trust more? Obviously it helps to know the high mileage car’s history and have the comfort factor that it is well maintained. |
21st Sep 2017 1:21pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
Hello
Most older landrovers are like Triggers brush, Most parts can be replaced cheaply. Keep it serviced it should be fine Welcome and look forward to your pictures and plans |
21st Sep 2017 4:13pm |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 287 |
I had similar concerns when I bought my 300tdi csw, however having used it a main vechicle over the past 6months or so I've had no major issues. The advice I was given was as long as the chassis and bulkhead were solid, and dont be too concerned about wear and tear on mechanical parts as these can easily be replaced. Admittedly I did a bit of work on it when I first had it but that was more on the chassis/body areas.
So as others have said just enjoy it. 1999 300TDI 110 CSW BMW 3.0 1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
22nd Sep 2017 8:52pm |
As others have said, enjoy it! If you service it regularly and keep it well maintained, high milage is no problem. My 300 Tdi from 1996 has 388 k km on the clock, it is my daily driver (and only car), and I trust it to start a 2000 km trip any moment. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
22nd Sep 2017 9:24pm |
TimS Member Since: 06 Jul 2015 Location: Northants Posts: 20 |
Echo all of the above. Mine had 226k miles on it and the engine ran fine.
With that kind of mileage, there will be wear and tear on friction areas - bearings, oil pump, thrust washers, cam lobes and followers, crank journals, piston rings and bores. Also seals will start to perish. The 300tdi is a tough old engine and will run happily even with major wear. Just keep it well serviced and I would advise changing the timing belt, water pump and checking oil and combustion pressure to give you an idea whats going on. Also check the turbo for play and excess oil and pop the intercooler and inlet manifold off to check them through and give them a good clean. If there is excess oil in these then you may have a turbo issue which is common at higher mileages and easily fixed. Undoubtedly the previous owner had work done so its worth speaking with them to find out what has been repaired/replaced to give you some idea of what still needs looking after. Its a simple engine to maintain and fix so get out and enjoy it! |
22nd Sep 2017 10:28pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
Good advice from Tim
I know its slightly different but we have a fleet of over 200 mostly Cummins and Mercedes engines (slightly larger ones than ours) but we change them at about 450k miles, many of them exhibit no major wear when removed for overhaul, the duty cycle is a lot different however to the average car. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
23rd Sep 2017 6:17am |
Thanks all for the advice! I'll be sure to enjoy every trip and maintain it properly. It's nice getting to talk to people here who love their Land Rovers as much as me (or even more! ) Here a few photos of my 90 before I make any additions and modifications (still deciding what colour to go with for the repaint)
23rd Sep 2017 6:25am |
that looks smart, i think there were some timing belt mods in that era, suspect its been done but may be worth checking DEFENDER 90 TDCI XS,
23rd Sep 2017 7:26am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10491 |
Welcome and a good looking landy you got there As others have said about maintenance regularly serviced will be a good thing, i service mine every 6000 miles and im on 317k now enjoy your time with your landy 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. Last edited by L110CDL on 22nd Jan 2018 10:20pm. Edited 1 time in total |
24th Sep 2017 10:25pm |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 |
Congratulations on your taste. As others have mentioned, if they are looked after Defenders can do stellar mileages. I had a 300 110 from new and put 322,000 miles on it in 12 years. The only thing I did was to shorten the service intervals to 5000 miles once it got past 100,000 miles. Just to keep the numbers simple.
A friend has a truck that is approaching 700,000 miles, it started life as a V8 was converted to a BMW straight six and currently runs a Brazilian 2.8 Tdi. My own v8 has done approximately 380,000 miles and is still going well, if expensively, lots of petrol and oil changes every 2,500 miles. |
26th Sep 2017 2:25pm |
