Home > Td5 > Turbo actuators
excossack
Turbo actuators
While mooching around I spotted this for sale
http://www.ebay.co.uk/itm/Land-Rover-Defen...SwmgJY743L
Not seen many knocking around for sale, they all appear to come with new turbos. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #649884 12th Sep 2017 5:51pm
lightning
He's sold 141 of them.
Is it an item that fails? I've never heard of one failing. They must do though, if he's sold 141.
Post #650109 13th Sep 2017 4:17pm
bankz5152
They can rot out and the diaphragm can fail, not often but it does happen.
Post #650110 13th Sep 2017 4:20pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
I have heard of them becoming stiff to move. I have a posh s/s one to fit (removed from my TD5 Disco)
https://www.forgemotorsport.co.uk/Adjustab...-1033.html
Post #650138 13th Sep 2017 6:23pm
excossack
How stiff is too stiff? 1999 Defender TD5 110
Regards
John M0VAZ
Post #650169 13th Sep 2017 9:18pm
JustFX
Never measured it. But some would claim theirs had become stuck and needed and bit of work and oil to get them moving again.
I replaced mine while tracking down an issue with the engine...turns out piston had cracked turning the engine into a steam traction engine if I took the Oil filler off.
Post #650174 13th Sep 2017 9:40pm
excossack
In replacing the actuator it would be hard to say if it made any noticeable difference for you then given you had a cracked piston 1999 Defender TD5 110
Regards
John M0VAZ
Post #650177 13th Sep 2017 9:46pm
JustFX
I drove with a rather knackered engine for a year before it got to the point where I said...bye.
There was a lack of power at times, turns out the oil system was pressurising causing a lack of oil to the turbo and that meant I killed a turbo eventually. I was trying cheapest options first as I had spent a fair bit on the LR over the years I had it.
Post #650181 13th Sep 2017 10:02pm
