Home > Off Topic > Increasing roll resistance? |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
I understand that ultimately the road springs are responsible for the amount of body roll experienced in a vehicle and that in order to have a less uncomfortable ride an anti roll bar is used to moderate the effects of cornering at speed. Further to that i get that increasing the stiffness of the anti roll bar bushes offers an improvement in the efficiency of the bar without going as far as a heavier section bar, a half way house of sorts.
I also know that the panhard rod is primarily there to provide lateral location to a beam axle while still allowing vertical movement of either end. On the same basis as the anti roll bar bushes being stiffer helps the effectiveness of the bar to resist rotation would stiffer bushings in the panhard rod have a contributory effect of also reducing the initial lateral component of the body roll , or is that additional stiffness just going to overly stress mounting points with no additional benefits. I am and probably always will be cynical to fitting polyurethane bushings to every joint in the suspension because I see a compliant ride as being a good idea in general, but certain features like being able to corner without the need for stabiliser wheels is also good. Thanks in advance. Rhubarb and custard let fly with their secret weapon. |
25th Aug 2017 5:29am |
The Panhard rod is a much longer lever than an ARB so I'd think that to make any difference the bushes would have to be so hard that they'd put undue stress on the mountings. Darren
25th Aug 2017 8:23am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2198 |
Very much doubt that stiffer bushes on the panhard rod will not make any noticeable difference. Additionally polyurethane bushes have a metal inner sleeve which can rotate pretty freely, therefore would actually allow an easier rotation of the panhard road around the bolts.
If you want reduced body roll without compromising ride quality I suggest thicker anti-roll bars and/or progressive rate springs. Be aware that having any weight at height on the vehicle will have a very drastic and detrimental effect on the body roll. Especially with the upper body of the Defender being quite lightweight (i.e. roof rack/tent, spare wheel on roof or high on back door etc.) I find taking the 255/85 spare out of the load bed on my DCPU makes a huge difference to how much it rolls. Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale Mobile Diesel Heater Build Thread |
25th Aug 2017 9:48am |
Thanks for the advice guys, that is what I was thinking. I have never been a fan of polyurethane. Rhubarb and custard let fly with their secret weapon.
25th Aug 2017 4:25pm |
