Home > In Car Electronics > Cisbo Parking Sensors Install |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
They have an orientation (should have a top mark of some kind) and also standard ones don't work mounted in metal 2002 90 Td5 Station Wagon
13th Aug 2017 8:20pm |
The top mark should be on the rear of the sensor 2002 90 Td5 Station Wagon
13th Aug 2017 8:21pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2065 |
Ahhh didnt know there was an orientation!
Dont work in metal? How come? They are inside a plastic and rubber sheath surely that shouldnt make a difference? |
13th Aug 2017 8:32pm |
Did you get the wiring right? According to the manual (found on the web, but not sure it is the right one) the yellow wire goes to stop (brake) light, red to reverse and black to earth... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
13th Aug 2017 8:52pm |
Interesting, why would it go to the brake light? The wires where labeled yellow clearly had "ignition 12v" on it.
13th Aug 2017 9:08pm |
Because when you stop, the buzzer stops buzzing?
Was a manual not included? Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
13th Aug 2017 9:10pm |
Suppose so but buzzer also stops buzzing when you take it out if reverse!
It did, i followed the instructions and hace an issue hence the post! Contacted the seller as well see if they can shed any light. What I dont get is why the ignition live actually does nothing, connected or not it still beeps. |
13th Aug 2017 9:19pm |
I'm pretty sure it's to do with the way the sensors generate their pulse and then 'listen' for the echo.
Me and my dad fitted a set of normal parking sensors into the metal bumper on the back of his van. They never worked properly and randomly beeped with nothing there or didn't go off even if you were 6 inches from a wall. Total rubbish! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Aug 2017 10:12pm |
Bloody hell! Utterly pointless on a defender then as plastic is few n far between! That said ive seen fenders with sensor mounted directly into the xmember!
13th Aug 2017 10:15pm |
Apparently there are metal specific ones. Or you can get ones with dedicated plastic brackets 2002 90 Td5 Station Wagon
13th Aug 2017 10:24pm |
Hmmmm!! Ill look into it, the ones ive got are a sealed unit, surrounded by a rubber sheath, then wrapped in plastic and mounted into my NAS step. Should be pretty insulated against the metal!
13th Aug 2017 10:29pm |
https://www.amazon.co.uk/Quanan-Parking-Se...B005FE7T1Y
Taken from the description of the above kit The system does not like most of systems in the market that are not suitable for metal bumper, it special designed for both metal and plastic bumper, can be for any Car, Pick up truck, Van, SUV 4*4. 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
13th Aug 2017 10:35pm |
Cheers! Ill have my leccy mate double check my wiring and take in account the suggestions above, if all fails ill go for tha.
I went for the Cisbo kit as it had brilliant reviews inc some from landy owners! Im wondering if for some reason the LED light is causing an issue |
13th Aug 2017 10:43pm |
the gamekeeper Member Since: 01 Jan 2010 Location: Surrey Posts: 96 |
These parking sensors are all over rated, there's nothing wrong with a Dixon and bates when you hear the rattle your in the zone.
14th Aug 2017 5:01pm |
