Home > Maintenance & Modifications > Black metallic samples |
JeremyJ Member Since: 16 Nov 2011 Location: Aylesbury Posts: 1758 |
Java doesn't have the metallic santorini has, I'd have santorini over java!
13th Aug 2017 4:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19525 |
I did wonder if Java was at all metallic but it is listed as such.
Santorini seems much more popular. Think I'll go with that. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
13th Aug 2017 4:25pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2494 |
I thought Java Black was pearlescent whereas Santorini is metallic. I'd go for Santorini but I'm slightly biased.
Click image to enlarge Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
13th Aug 2017 4:27pm |
From memory, Java has grey/silver flecks in it and santorini also has red and green flecks. Personally I'd go for santorini, and I did on my roof, wheels, bumper and rear crossmember Ray
13th Aug 2017 4:39pm |
Best pic of santorini I could find from when I painted my grill
Click image to enlarge Ray My build thread http://www.defender2.net/forum/topic17615.html |
13th Aug 2017 5:00pm |
^^^^ Yep that's the one MK1. I remember your pic and liked it very much at the time.
Stornoway & Santorini it is. I want to do my dash dial rings black, and my fan vents each end. Sub Grille Stornoway, and Centre dash stornoway which are black right now too. Cannot make up my mind on the centre fan rings, they are silver as standard. I have them black at the moment but could go with Stornoway also. So it's either, sub and centre dash Stornoway and black rings in the centre or Stornoway also. At the moment everything is black and I definitely want Stornoway sub grille and centre dash. What would you go with? Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
13th Aug 2017 5:38pm |
I think I'd keep all the rings the same colour, so either rings black with console and grill grey or rings and console black with grill grey. Ray
13th Aug 2017 5:51pm |
Sounds good to me, all black as is but metallic. And Stornoway centre dash and sub grille.
I'll get on with it as soon as I get time, doing it in winter time is a real pain. So hopefully within a month or two max ideally. Diesels Lives Matter. ⛽️🛢️👨🔧🧰⚙️ And if You Love the Country, then we’re on the same side ~ I got’ love for Britain, I got’ British pride’. 🇬🇧 |
13th Aug 2017 8:32pm |
Always better to do painting in summer if you don't have a paint booth. When I get time I'm altering my centre console on the td5 to fit a double din, then painting it santorini. Ray
13th Aug 2017 8:38pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
Not sure if these help? Santorini, I'm planning on giving it a polish prior to Scotland road trip to help with getting the bugs off easier. I will try to get a close up
13th Aug 2017 9:08pm |
Found a couple...
Unless your close though its harder to tell, looks great in the flesh Click image to enlarge Click image to enlarge |
13th Aug 2017 9:13pm |
Cheers guys, very busy at the mo but will be getting on with it shortly hopefully.
13th Aug 2017 9:54pm |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
When I had my new doors painted in Java black to match the rest of the truck the body shop paint man mentioned that it contains blue pearl flecks. It's certainly very subtle and could easily be mistaken for flat. I'll try to get a close-up that shows it. |
14th Aug 2017 12:42am |
This is Java Black close up. It has a very subtle pearlescent fleck which can just be seen in the photo. Add a bit of road grime and it could easily be mistaken for a flat black.
31st Aug 2017 10:46pm |
