Home > Puma (Tdci) > Gearbox (MT82) filler plug... |
Drain plug
Filler plug DO NOT USE the filler plug for the oil level..... You MUST fill in the right quantity (otherwise the pressure can give you oil leaks from the oil seals) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
28th Apr 2011 9:46am |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Solved the mystery!!
Took a trip to Halfords to get the required Torx bit.. I managed to get the "assistants" to let me take the T50 and T55 bits out of the store to check the size before I paid.. Turns out that both the filler and drain plugs need a 12mm allen key and not Torx bits, so had to ask again if I could take more stock outside without paying!! I tried a 12mm 1/2 inch drive Allen key, fitted perfectly, now here's the rub, you cant get a bloody ratchet in the space to undo the filler plug. Buggritt!!! Then I saw a set of drain plug keys hanging on the stand, took them outside, and checked that they would fit.. The 12mm key fits perfectly, and along with a 19mm ratchet ring spanner, the plug is easily removed and replaced. Cost £19.99 for the set, but will come in useful for other jobs.. ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
28th Apr 2011 11:01pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2260 |
Not sure if it is a pressure matter but rather a lubrication design issue. The MT82 fitted on Mustangs uses 2.6l. Puma 110" SW ............................................................. Earth first. Other planets later |
1st May 2011 11:25am |
Milmur64 Member Since: 05 Oct 2016 Location: Perthshire Posts: 33 |
Hello I have a 2015 Defender with the 6 speed gear box MT82. The vehicle has done circa 13k miles and I want to change the gear box oil. Found the outlet plug but struggling to establish which is the fill plug. I have researched via the internet/ Yuo Tube, etc and i am more confused than ever! Local dealership was no help which is sadly very disappointing and just gave me a set of isometric workshop manual drawings which was of little help due to poor quality of copy.
Can someone advise me please. Attached photo of an 8mm hexagonal plug on driver side that I think might be the filler appeture, but I am unsure? Any advice will be appreciated. Regards, Jonathan Click image to enlarge |
11th Aug 2017 7:20pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3613 |
see dgardel post above with pictures DEFENDER 90 TDCI XS,
11th Aug 2017 7:39pm |
yes it is! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
11th Aug 2017 8:00pm |
You MUST fill in the right quantity (otherwise the pressure can give you oil leaks from the oil seals) ? has gear box not got breather pipe work |
11th Aug 2017 8:55pm |
I think it does..
In my case I replaced both fill and drain plugs with std bronze ones. Puma 110" SW ............................................................. Earth first. Other planets later |
12th Aug 2017 12:24am |
Many thanks everyone the advice and information has proved invaluable. Regards Jonathan
12th Aug 2017 7:59pm |
It does, it's probably more to do with certain seals in the box not being designed for constant submersion in oil. Some gearboxes also generate their own pressure internally rather than being simply splash fed. Either way the MT82 in the Defender is designed and tested to take 2.2 litres for a service change it's not designed as a spill fill box, so putting any more in will simply be a waste of oil at the very least. |
13th Aug 2017 2:53am |
Many thanks for all the additional information regarding the MT82 box all very useful and confidence boosting.
Once again thanks to everyone who has taken the trouble to reply to my initial post - very much appreciated! Regards Jonathan |
14th Aug 2017 9:18am |
MT82 Getrag Work Shop Manual
https://1drv.ms/b/s!AnHBx4Wc2MJLhD46SXKHxgIs4mgo Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
18th Aug 2017 10:47pm |
